Thread: Fuel line nut size
Results 1 to 9 of 9
  1. #1 Fuel line nut size
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    The end on the line cOnnecting to the fuel filter. Figure someone can save me from crawling uNder the car till I snatch a line wrench. This is my last shot at changing this stupid rusted line/
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: Fuel line nut size
    to good to use vise grips are ya lol
  3. #3 Re: Fuel line nut size
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    if u disconnect the quick connect line and mounting bracket you can usually just twist the filter off. if i had to guess id say like 7/8 or 1"
  4. #4 Re: Fuel line nut size
    Oct 2008
    IL
    Lol been there. My nuts are so rusted that will never get it off.
    Quote Originally Posted by bps02gtp View Post
    Oh no there is no just twisting this filter. Im pretty sure this is the stock filter
  5. #5 Re: Fuel line nut size
    what hes saying is not to even try to break the line nut free. hold the nut tight, and turn the filter, so it comes off the nut. that way the nut stays frozen to the line, and you dont twist the line.
    vice grips work great lol
  6. #6 Re: Fuel line nut size
    Oct 2008
    IL
    Oh I know. Been there done that tho lol. Im hoping since its hot as ballz out that may help. Im taking a wire brush to it daily now to see if that will help the PB creep in there and PB again for a week or so then gonna go one more round. Im going to use a line wrench most likely tho. I need to find a heat gun that is a litle more adjustable heat that mine. If I can keep the heat around 400 Ill be good since gas isnt famable till 495 but thats a far stretch IF I do that. Ill take a pic of how bad its rusted. I bet you already know all about this issue tho.
  7. #7 Re: Fuel line nut size
    Nov 2010
    Illinois
    man its really seized on there then. my nut was rounding out and i just twisted the filter right off. screw using the heat gun id rather just cut it off and put new line on there.
  8. #8 Re: Fuel line nut size
    Minnesota
    It's a 20mm
  9. #9 Re: Fuel line nut size
    Oct 2008
    IL
    Quote Originally Posted by Pure2sin View Post
    It's a 20mm
    Thanks buddy just trying to not climb under the car till I gotta.
  1. brake line size (97-2003_
    By sasquatch094 in forum General Tech Discussion
    Last Post: 10-06-2011, 09:53 AM
  2. Vac Line Size
    By Spartan GL in forum General Tech Discussion
    Last Post: 05-03-2011, 01:46 AM
  3. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  4. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  5. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
