Thread: 2007 grand prix .........please help
Results 1 to 8 of 8
  1. #1 2007 grand prix .........please help
    May 2012
    Ottawa
    hello I have a 07 gp no supercharger and it has a 3.8l engine
    i was hoping someone could give me some advice? my car has been starting and then stalling before it should idle?
    sometimes it tries to idle but if I put my foot on the gas a little it will fire up perfect? it has been doing this for 6 months and just having
    a baby I a putting off the garage as long as i can. The car also shutters at 60 km's so I have to give it more gas pedal to smoothen out.
    the is no check engine light on? any help would be great! thanks
  2. #2 Re: 2007 grand prix .........please help
    stalling at first start up could be a very very dirty throttle body and maf sensor.
    I would take those off and clean them with the correct cleaners.
  3. #3 Re: 2007 grand prix .........please help
    And ....I agree. That's the best place to start
  4. #4 Re: 2007 grand prix .........please help
    GTX Level Member SF9777's Avatar
    Jan 2012
    Anaheim, Ca
    I got a 07 GP base as well, mine had the exact same problems. Go to Autozone or your local auto parts store and buy a Throttle Body cleaner and a MAF Sensor Cleaner. Use the MAF Cleaner and spray your MAF and set it aside to dry, then use the Throttle body cleaner to clean the Throttle Body. If you open up the throttle body you will see that it is very badly dirty. Once your done with that put it all back together and take a quick test drive, you will see that you Throttle response will be much much better.
    Check this out if you need help
    Grand Prixs Of North America • View topic - clean your MAF & Throttle Body
  5. #5 Re: 2007 grand prix .........please help
    Pennsylvania
    I just like to stress the importance of NOT touching the Maf wires with anything ever, spray them thoroughly and let it dry 100%... No touching anything. I've seen a few people ruin the sensor thinking they could gently wipe off the wires with a soft cloth or something
    Just soak it and sit it down.
    Sport Edition Kv5 18x8
  6. #6 Re: 2007 grand prix .........please help
    Jan 2012
    Anaheim, Ca
    ^^ Yes DO NOT TOUCH THE WIRES IN THE MAF. All i did is spray it and gave it 20-30mins to dry completely, may not even take 15mins but just in case. Also i would not spray inside the TB, i would soak a ragg in the TB cleaner then clean the inside of the TB
  7. #7 Re: 2007 grand prix .........please help
    Pennsylvania
    Quote Originally Posted by SF9777 View Post
    Just remove the tb off the plenum, it's only 4 bolts, takes 10 minutes.. and you can clean so much more thoroughly. Seriously, just do it... do it. There are big results as far as responsiveness goes.
  8. #8 Re: 2007 grand prix .........please help
    Jan 2012
    Anaheim, Ca
    Quote Originally Posted by FriboRage View Post
    I meant the part that is after you take off the 4 bolts, i know to do that.
  1. Can TC be turned off on a 2007 Grand Prix GT
    By cpr in forum General Tech Discussion
    Last Post: 01-29-2012, 12:55 PM
  2. My 2007 Grand Prix GT
    By carlover89 in forum Members Rides
    Last Post: 01-07-2012, 03:02 AM
  3. 2007 Grand Prix
    By kristinkay in forum Introductions/Noob Questions
    Last Post: 07-29-2010, 02:23 PM
