Thread: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plugs.
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    May 2012
    Surrey, British Columbia, Canada
    Ok so I'll find a spare ECM and probably just send off for a pre boxed tune. I am a computer tech by trade so I don't think doing the tune myself would be that much of a hastle, however honestly I am not "their" yet at this stage of the building with the car. Right now I am just worried about getting the most out of the semi stock car that I can. I mentioned earlier, that I was going to take the car in to a local shop for an oil change, not because I could not do an oil change myself, but I wanted to get the car up on the hoist and inspect the undercarriage of the car. Well what I found totally blew my mind and is very unexpected.
    Looks like the left rear control arm / trailing arm was hit or damaged. There is no body damage and no rim damage, so best I can figure is someone (not me) tried to jack the car up from there and bent it.
    It must be a fairly old issue, and the car has since been alligned to take into account the shorter control arm. The car tracks perfectly straight and handles well. None the less I am going to try and locate a new control arm asap.
    Here is a pic of the damage control arm.
    New GTP Owner. Totally Stock. Yes I am keeping the motor in the GTP, No I am not stealing it for one of my Fiero's. Car Details; 2000 GTP 3800 S/C Auto. Bose Audio. There have been Zero mods done to the car, so starting from a clean slate.
  2. #22 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    At least go for boxed ones.
    IIRC the dormans are boxed.
    If you wanted to go used part hunting, impala cop cars had tubular bars from the factory.
    GM used to sell those as GMPP but they've been discontinued.
  3. #23 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    May 2012
    Indiana, PA
    wow, that is weird... the buckles on each side are both in the same direction so at one time it was bent to the side.
    If it was jacked up and that made it bend, you should have seen both buckles in an outward motion... at least the civil engineer in me tells me so...
  4. #24 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    It's a common thing for these cars honestly. A lot of people try jacking them up there and bend them, they don't realize that the arms are not made for handing a load. Also, they are not control arms, they're trailing arms.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  5. #25 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    I live here. TLSheff's Avatar
    The GMPP trailing arms are not Discontinued actually. The would likely have to be special ordered, would take a couple days, but they are in the warehouses.
    GM #25990164 - retail $40 each
    Call your local dealer and see if they can get them.
    EDIT: Keep in mind the factory replacement POS like you have that is bent is GM# 10282766 - Retail $77.00. Give them the # and have them price it and tell you when they can get it. Don't just give them your vehicle info, it won't match. The GMPP is for an impala.
    Jan 2009
    Tallahassee, FL
    You can go aftermarket with them, my UMI arms were $110 and are super beefy.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  7. #27 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    Banned
    CT
    Get some headers on there man... your plugs indicate it's knocking pretty badly.
  8. #28 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    Apr 2008
    Southern KY
    Quote Originally Posted by SnowFlake View Post
    Joke? He's totally stock and all I see are worn plugs. No bent side electrodes or anything that I'd consider relevant to abuse within the chamber.
  9. #29 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    Banned
    CT
    Quote Originally Posted by RooK View Post
    Not a joke at all... those plugs are covered with signs of knock. Must have been really bad to leave layers like that on the plug.
  10. #30 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    May 2012
    I was thinking that I would find someone on here with a good used OEM one, however further posts have me thinking twice about that.
    Quote Originally Posted by chrisatpsu View Post
    Honestly your guess is as good as mine. However with Zero body damage or rim damage, the only thing that I can think is a jack or gasp someone drove off a curb really badly.
    I have seen this before on 88 Fiero's, and in the Fiero's case, there are no replacements, GM quit making them years ago, and NO other car ever used an 88 Trailing arm. Last I checked there was 1 aftermarket company charging $450 for a set. Which may no longer even be around.
    So if I am reading that right, I can pay $77 and get a weak OEM, or $80 for a set of the better ones. It does not sound like a good idea to have one OEM and one upgraded trailing arm. Thank You VERY MUCH, for all the part numbers will make it much easier.
    Quote Originally Posted by Sandman View Post
    If I were going to take this car out Autocrossing or Road course I would probably go with something extra heavy duty, but as much fun as I am having with this car, I keep forgetting that this car was bought to haul around our 2 year old and soon to be born new baby. I think upgraded stock parts will be fine. However thank you for the info, I'll keep it in mind.
    The car was owned for 11 years of its life by a nice old couple, however directly before we bought it, it was owned by another guy for 4 months, it is possible that he ran cheap gas in it, then drove it rather hard. As well as the really bad plugs, the combustion chamber temps could have been hot enough to get some pre-ignition. However now that we own it, it will finally get treated right with a steady diet of 94oct and good parts with regular maintenance and regular ECM scans to keep an eye on KR.
    Thank You Everyone, you have all been amazing with the help.
  11. #31 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    Apr 2008
    Southern KY
    Quote Originally Posted by Capt Fiero View Post
    Ehhhh? For that price I'd just take the factory one, cut the bent U-channel off, cut a metal rod to length and have it welded between the two ends. Probably be less than $50 per side.
  12. #32 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    May 2012
    I waited to reply to this thread until I had the cradle out of 88GT. (swapping the alternator, bolt got siezed so decided to just swap the engine along with it, granted the slipping clutch and bad rings did aid in the descsion)
    The 88 Trailing arm is not just a straight piece, the angles have to be perfect or else you get bind in the suspension. (all the pics from today are at, May 27th 88 Fiero Engine Pull but didn't want to clog up this thread with too much Fiero stuff)
    I have decided to go ahead and grab a pair of Impalla arms and put poly in them. Seems to be a good deal and will get me a start on my poly install for the entire car.
  13. #33 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    Apr 2008
    Southern KY
    So I see says the blind man. Still... you could make a jig that replicated that angle in a few hrs and still make them for almost nothing.
  14. #34 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    Out West
    These cars knocked from the factory. Every last one of them.
    Whine with your Cheese?
  15. #35 Re: .120 Gap Spark Plugs, New Cone Filter install, New Wires and Road Trip. Worst Plu
    Nov 2011
    NY
    HT Motorsports Trailing arms... nice and very reasonably priced.
    I can't believe those plugs though... wow! Engine must feel great after changing those out with new wires too.
  1. Which Spark Plugs & Wires Should I get??
    By milo033 in forum General Tech Discussion
    Last Post: 12-27-2010, 06:38 PM
  2. Best Spark Plugs and Wires
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2010, 09:55 PM
  3. Spark Plugs and Wires
    By FormulaW66 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2010, 04:55 PM
  4. Spark plugs and wires
    By JB381 in forum General Tech Discussion
    Last Post: 03-08-2010, 04:07 PM
  5. New Spark Plugs and Wires
    By rileystanek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 02:31 AM
