Thread: Catalyst Monitor "Not Ready"
Results 1 to 5 of 5
  1. #1 Catalyst Monitor "Not Ready"
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I have a 1999 GP GTP that runs absolutely amazing and gets great gas mileage. AFAIK, I have no problems with the catalytic converter itself. I have a cheap code scanner that also tells you the readiness states of the various emissions tests. There are absolutely no codes being thrown, and my car is 100% stock aside from a short air intake that I built. However, the catalytic converter displays "Not Ready" after at least 500 miles of driving and probably 30+ times being run for a trip and then shut off.
    What could be the problem? Do I need to wait longer?
    I don't live in a state with emissions testing, but just the fact that this is not right bothers me.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: Catalyst Monitor "Not Ready"
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    I don't know for certain what the problem is, but I would trace the wiring to the rear oxy sensor it goes down behind the alternator and into the shield above the cat if the sensor is not getting voltage to heat up to working temp it will give this code. It might have gotten too close to the exhaust and be burnt/broken or maybe the sensor is bad. I think the rear oxg sensor because if it was the front one it should be giving you bad gas milage. good luck
  3. #3 Re: Catalyst Monitor "Not Ready"
    Cut it out.
    Who cares about emissions.
  4. #4 Re: Catalyst Monitor "Not Ready"
    Houston
    Cut it out.
    LOL! I do! Just finally got my car inspected today after 2 1/2 years. My catalyst has always shown "not ready", was told it has something to do with the high flow cat. If you're not experiencing any issues, just forget about it.
  5. #5 Re: Catalyst Monitor "Not Ready"
    May 2012
    ohio
    at 235k i would say the cat is dead or real weak, cats get HOT real hot when working properly the rear o2 sensors monitors the cat emission output if u look at it on a good labscope it would show a flat line waveform, where the front o2 shows a waveform that looks like a snake it does monitor the amount of oxygen coming out of the engine and adjust's the fuel richer or leaner depending on need. If the cat is not hot enough it may show a ripple in the flat line waveform causing the cat not ready, may not be enough to set a code, if the heater in the o2 were bad or the sensor was dead it should set a code. The cat and the o2 sensors usually dont make it that long without a problem, it will not cause a fuel mileage issue would not worry unless u need a emission test
  1. how to remove "Service Tire Monitor System"
    By 04GT in forum 04+ Specifics
    Last Post: 12-20-2011, 10:13 AM
  2. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  3. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
