Thread: Replacing Needle Bearings
Results 1 to 6 of 6
  1. #1 Replacing Needle Bearings
    Jan 2012
    Philadelphia
    I have an extra gen 3 that was on my car and the needle bearings are bad i want to replace them, no scense having a bad blower laying hear might as well fix it. anyone ever replace these? need some advice on how to remove the old ones.
  2. #2 Re: Replacing Needle Bearings
    Jan 2012
    Philadelphia
    any advice?
  3. #3 Re: Replacing Needle Bearings
    I think you have to drill and tap the holes and thread in a grease zerk and push it out with a grease gun but i could be mistaken.
  4. #4 Re: Replacing Needle Bearings
    Jan 2012
    Philadelphia
    sounds like that could work never thought of that
  5. #5 Re: Replacing Needle Bearings
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    That's exactly how you remove them.
    Lambokit to be built!!!!!
  6. #6 Re: Replacing Needle Bearings
    To swap out bearings in an SC. Either follow the directions at RollingPerformance.com or see below
    Get this crap
    Drill and tap the holes wtih red in them in this pic. (Gen 3 M90)
    Thread NPT pipe in and then put nut on, and screw your grease gun into the pipe/coupler
    Squeeze until bearing pops out.
    Wipe out grease and press in new bearings.
  1. Replacing snout bearings
    By vsl67 in forum How To Write-Ups/Tech Tips
    Last Post: 12-29-2010, 07:20 PM
  2. Needle Bearings falling out of Driver Trans Axle
    By justlookin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2010, 07:44 AM
  3. Replacing bearings for SC case
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2009, 02:31 PM
  4. Guage needle
    By DDPeppa in forum General Tech Discussion
    Last Post: 06-01-2009, 03:25 PM
