Thread: Dashboard lights going crazy
Results 1 to 4 of 4
  1. #1 Dashboard lights going crazy
    SE Level Member jamster00's Avatar
    Apr 2009
    san diego
    Hi all,
    I have a 2001 GTP and just the other day I went to turn on the fan while I was driving then all of a sudden the dashboard lights (ABS, Check Engine..etc) was blinking on off, radio not working, windows will not go down..etc. I turned off the fan and went back to normal. Can anyone tell me what the heck is goin on? BTW - A few weeks ago my key will not completely go to the off postion intermittenly but I found the release button on the bottom of the steering column. Is this also related to my dashboard problem? - Note - when I got home, I turned on the fan and it did not happen.
  2. #2 Re: Dashboard lights going crazy
    St. Louis
    Sounds like you have a ignition switch going bad.
  3. #3 Re: Dashboard lights going crazy
    Apr 2009
    san diego
    Thanks for the info FordMan77. I drove the GTP today and all is good until I turned on the fan, my DIC display blinked a few times then it went normal, I turned off the fan then turned it on again and it did the same DIC display blinking on/off. Is this an ignition switch problem or combination with the fan blower motor?
  4. #4 Re: Dashboard lights going crazy
    St. Louis
    Might be a problem w/ the blower motor resistor, or possibly the HVAC unit itself. I know I've seen a thread on this here somewhere. If someone doesn't chime in do a quick search and see what comes up.
  1. dashboard repair
    By tdm571 in forum Visual/Body Modifications
    Last Post: 03-01-2011, 11:02 PM
  2. dashboard rising
    By grandprix97gp in forum Off Topic Discussion
    Last Post: 11-08-2010, 09:40 PM
  3. Dashboard creaking
    By kharma1 in forum General Tech Discussion
    Last Post: 01-05-2010, 07:53 PM
  4. Dashboard lights
    By Skeeve in forum Audio, Security & Visual Electronics
    Last Post: 10-06-2009, 10:35 PM
  5. dashboard lights and taillights off
    By ricardo23 in forum Audio, Security & Visual Electronics
    Last Post: 10-03-2009, 04:56 PM
