Thread: coil isues
Results 1 to 10 of 10
  1. #1 coil isues
    GT Level Member gunsn88's Avatar
    May 2011
    Vineland, New Jersey, United States
    okay so i was driving down the road and out of knowwere my car felt like it hit a wall. i had to put home luckly i was down the road. when i checked what was going on one og my coil packs was bad so i was running on 4 cyliners. i replaced all my spark plugs and got 3 new coil packs. the timing chain is still good i thought it broke. but my cars still running on 4 cylinders and and for some reason its not getting a spark. can it be my ignition module? if so thats the last thing i can replace that would be the cause. any help.
    Imagination is more important then knowledge.
  2. #2 Re: coil isues
    icm, under the coils.
  3. #3 Re: coil isues
    May 2011
    yeah thats what i was thinking. does that seem right?
  4. #4 Re: coil isues
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    2x icm and yea sounds like the symptoms
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  5. #5 Re: coil isues
    May 2011
    damn it. theyre mad expansive. 180$. i was just driving down the raod and bam
  6. #6 Re: coil isues
    May 2011
    also im having ingition switch isues. would it be better to get the whole harness or just the ignition lock sylinder? and will i need a new key?
  7. #7 Re: coil isues
    brunswick
    im parting outa gtp.. i have one :-) and what is wrong with the swith
  8. #8 Re: coil isues
    go to a junk yard for the icm, they are a lot cheaper used. or find one on ebay.
  9. #9 Re: coil isues
    May 2011
    i found on e on ebay for 30$ new. just orderd it, and my switch i can take the key out while its in drive and sometimes it gets stuck in the ingnition when i turn car off. so i have to put car in reverse then drive to get it out. and sometimes when i take the key out its in accecery and i dont even know and it kills my better, 2 times my car just shut down out of knoiwwere for 20 mins then randomly came back on
  10. #10 Re: coil isues
    May 2011
    also, idk if i just need a ignition switch or the whole switch and harness because a couple times when i tried turning my car on and it shut down my car for 20 minutes. idk what to do
  1. coil packs keep going out???
    By chamberlain198437 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 10:33 PM
  2. coil pack
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-13-2010, 12:22 AM
  3. Coil Packs
    By snodly in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2009, 09:04 PM
