Thread: Something fell off my car.. what is it? o_O
Results 1 to 7 of 7
  1. #1 Something fell off my car.. what is it? o_O
    SE Level Member Paramedic's Avatar
    Aug 2011
    Canada
    I was driving home from work and after leaving a store I stopped at I accelerated kinda quickly I guess and this thing fell off. It looks like a cover, its not too solid, I could flex it. I'm just not sure what it is. It's really wet out and I have nowhere to get under the car to look.
    I uploaded the pictures here: Postimage.org / gallery - Cam 203, Cam 204, Cam 205, Cam 206
    You call, we haul.
  2. #2 Re: Something fell off my car.. what is it? o_O
    Exhaust heat shielding.
    Its uselss, so dont worry about it.
  3. #3 Re: Something fell off my car.. what is it? o_O
    Aug 2011
    Canada
    Thats what I thought.. thanks
    You call, we haul.
  4. #4 Re: Something fell off my car.. what is it? o_O
    Pennsylvania
    Ahahahaha. Oh man. How shot are your engine/trans mounts that your engine could rock that much?
  5. #5 Re: Something fell off my car.. what is it? o_O
    Aug 2011
    Canada
    The holes around the cover were all rusted away. 11 winters are brutal. On a side note, whats the deal with replacing or checking these mounts? Is it hard to do by myself? Expensive?
    You call, we haul.
  6. #6 Re: Something fell off my car.. what is it? o_O
    St. Louis
    Not hard to do yourself. The hardest side is the pass side (the engine mount). You'll have to jack up the motor to remove and replace this one. Trans side is easy.
  7. #7 Re: Something fell off my car.. what is it? o_O
    the trans mount you also need to lift the engine up as well, i did both of them , took about 30 minutes a side tops.
    you need jack stands. ramps wont work, you need the front tires off. you need a wide board, 2x6 at like 1 to 2 feet long, and a jack, put the wood across the oil pan and trans pan, take the dog bones off up top, in the front there. remove the bolts that hold the mount in and jack the engine up till the mount clears, put new on in drop and bolt it back in, off to the other side, same deal.
    i don't think i paid over 60 or 70 for both mounts.
    search youtube, great vids for how to's.
  1. Lower door panle trim fell off - where to get a new one
    By stratman in forum General Grand Prix Discussion
    Last Post: 08-07-2012, 10:56 AM
  2. HELP! Little piece of dipstick fell into oil tube/reservoir
    By Noopsky13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-26-2011, 07:19 PM
  3. 2000 GP SE Lock button broke/fell into Pass. Door
    By postalc38 in forum Audio, Security & Visual Electronics
    Last Post: 01-23-2011, 11:21 PM
  4. plastic trim on rear door fell off, please help
    By Wraith888 in forum Visual/Body Modifications
    Last Post: 08-11-2010, 09:02 AM
  5. Part of the resonator fell off, should i fix it?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2010, 11:14 PM
