Thread: need help identifying whos prix this is
Results 1 to 4 of 4
  1. #1 need help identifying whos prix this is
    Port Huron
    I need to know if you found out what the problem was?
  2. #2 Re: need help identifying whos prix this is
    St. Louis
    Not my prix, but that sounds like a pulley with a bad bearing to me. If you have a sound similar, remove the S/C belt and start it up and see if the noise is still present. If so, then remove the main belt as well and see if it's there while running. Just don't run it very long w/o the main belt on it as your waterpump will not be turning (i.e.- less than a minute or so). If the noise goes away then check your waterpump and A/C compressor to see if they spin freely and quietly.
  3. #3 Re: need help identifying whos prix this is
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    its not a supercharger bearing i have a bad one and it does not sound like that
  4. #4 Re: need help identifying whos prix this is
    Port Huron
    We removed the belts and the sound w as still there. it sounds as though it is coming from within the timing chain cover. We removed that and saw extremely milded marks that made us assume it was the chain (double rollmaster) that stretched enough to make contact with the cover even with the machined plate in there. I bought to new cover gaskets and doubled them up and we put it all back together and the noise still there. I spoke with the person who's video that was (above) and he said he ended up having to replace lifters, and cam. I have an almost brand new S1X cam in there and i hope i didnt damage that already.
  1. Need help identifying part
    By hotshot26 in forum General Tech Discussion
    Last Post: 02-14-2012, 05:32 AM
  2. Need help identifying 1993 grille
    By rukind007 in forum Off Topic Discussion
    Last Post: 12-03-2010, 10:46 PM
  3. Need Help Identifying These Rims
    By nawarkk in forum Tires & Wheels
    Last Post: 11-29-2010, 04:05 PM
  4. Help identifying a part
    By RSTraveler in forum Introductions/Noob Questions
    Last Post: 10-18-2010, 02:43 PM
  5. Identifying a 4T65E-HD?
    By 2M8 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-02-2008, 07:56 AM
