Thread: My 2002 GT
Results 1 to 20 of 29
  1. #1 My 2002 GT
    Aug 2011
    nj
    These are the things that I have recently done to my GT. Fabricated cold air intake, installed u-bend straight pipe, installed 160 thermostat, changed oil to Royal Purple 5-30, changed coolant, changed brake fluid, changed tranny fluid and filter and installed ceramic pads at all four corners. Anybody have any other suggestions on what else to install for a performance upgrade? The car has 83k miles.
  2. #2 Re: My 2002 GT
    Dec 2011
    Philadelphia, PA
    SSAC headers or pacesetters, cheapest ones that i know of, and ER rockers along with hv3 insert and a tune, get the insert last out of all of them cause if u get it first (like i did) u wont feel anythin, then get ur tune
    AEM bruteforce intake
    Diablo 93 Octane tune
  3. #3 Re: My 2002 GT
    GT Level Member GrandprixGT01's Avatar
    Nov 2011
    Keswick, Ontario
    Quote Originally Posted by sLpGPGT View Post
    Really? I was going to go CAI, Mufflers, HV3, and tune route but do you recommend the headers as well?
  4. #4 Re: My 2002 GT
    Apr 2009
    Fort Worth TX
    There are many conflicting opinions about the 160 tstat. It may behoove you to do some more research. You're about 40 degrees below the operating temperature that the engine was designed for.
  5. #5 Re: My 2002 GT
    Dec 2011
    Philadelphia, PA
    Quote Originally Posted by GrandprixGT01 View Post
    yea headers is a nice addition, but hv3 is setup to go with ER rockers and a tune, and its prolly best mods to get on a N/A car next to top swapping and a cam, and yea do mufflers (i recommend SLP cause on mine it sounds real agressive) and for headers thats up to u i just suggested SSAC or pacesetters cause there cheap and get the job done
  6. #6 Re: My 2002 GT
    take 160 out.
    throw in garbage.
    Install 195.
    Carry on.
  7. #7 Re: My 2002 GT
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    Mufflers? Ha! Don't bother. Anything other that stock sounds terrible and will net you 0 ponies.
    CAI is a waste. Make your own open cone.
    Royal Purple is a sham. They were designed to run on conventional oil. Not fancy crap with purple in it. Go to Walmart and buy Castrol.
    Ceramic pads? What for?
    HV3 is good after rockers.
    Tune is must after any mod.
    The evil LG8 still refuses to die.
  8. #8 Re: My 2002 GT
    Aug 2011
    nj
    Is it really bad for the engine to be running this cool? What could happen?
  9. #9 Re: My 2002 GT
    Aug 2011
    nj
    BTW, what is this "tune up" and what does it consist of? Who does it?
  10. #10 Re: My 2002 GT
    Problem is with a really low-temp-open tstat the coolant just rushes thru all the time and you end up with overheating issues cause it doesn't stay in the rad long enough to cool (in layman's terms)
  11. #11 Re: My 2002 GT
    A tune (not a tune up, two different things) is the "parameters" if you will within which a motor will operate. It's written into the computer, which obviously controls what the motor does.
  12. #12 Re: My 2002 GT
    Quote Originally Posted by Steel Armadillo View Post
    Wrong. He can get away without a tune with what he could be doing. If he wants to take full advantage of what the car can do, then a tune will do him good.
    Stock Knock sensor dont turn on till 160º. Those are very important, so running that cold is a problem, also mpgs will suffer.
    A stock 195 is what the car likes. You can go to 180 if you please, but its not needed.
  13. #13 Re: My 2002 GT
    Aug 2011
    nj
    So maybe put a 180 in.
  14. #14 Re: My 2002 GT
    A tune can control things like air/fuel mixture, ignition timing, electric fan operation, trouble code reporting, transmission shift points, speed limiters and many other things.
  15. #15 Re: My 2002 GT
    Aug 2011
    nj
    Ok, so who does a "tune" and around what does it cost?
  16. #16 Re: My 2002 GT
    I agree, but as far as I'm concerned, wasting my time and money on a mod and then not taking full advantage of it is, well, a waste.
  17. #17 Re: My 2002 GT
    Aug 2011
    nj
    Ceramic pads cut down on brake dust.
  18. #18 Re: My 2002 GT
    IDK who does tunes in Jersey
  19. #19 Re: My 2002 GT
    Aug 2011
    nj
    Do you know of a web site, phone # or the town they're in?
  20. #20 Re: My 2002 GT
    Quote Originally Posted by getsumi shin View Post
    And rotors.
    I guess I clean my car so often I've probably forgotten what brake dust even looks like.lol
  1. 2002 gtp
    By Shaq7607 in forum Introductions/Noob Questions
    Last Post: 02-28-2012, 12:13 PM
  2. 2002 GTP vs. 2002 audi S4
    By JbrownGTP in forum Track Sessions and Kills
    Last Post: 07-07-2009, 11:50 PM
  3. 2002 gt
    By zbee in forum Introductions/Noob Questions
    Last Post: 05-04-2009, 07:04 AM
  4. 2002 gt
    By Snake in forum Introductions/Noob Questions
    Last Post: 05-01-2009, 08:38 PM
