Thread: should i run my ZZP underdrive pulley?
Results 1 to 20 of 29
  1. #1 should i run my ZZP underdrive pulley?
    Jan 2012
    Philadelphia
    I have a ZZP under drive water pump pulley i got it for free with my down pipe, im going to need a new belt soon and im not sure if its worth putting on it seams almost the same size as the factory (a lil bigger) but its defiantly lighter then the factory. Im not sure if i should put it on and buy a one size larger belt because im gonna need a new belt anyway, or should i just sell it and spend my money on something else? Its brand new, does anyone have one? If so is it worth putting on, and what benefits do you get? So what do you guys think is my best option if its not to big of a gain i could use the money to spend on something else for my car. Its a 97 GTP.
  2. #2 Re: should i run my ZZP underdrive pulley?
    not worth putting on.
  3. #3 Re: should i run my ZZP underdrive pulley?
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    heres zzp's take on it.
    ZZPerformance - Water Pump Underdrive Pulley #ZZ-WTRPUNDPUL
    i personally dont think its worth to buy but for free it wouldnt hurt to put it on. thing is you have to get a larger belt. then if you drop ur pulley size you have to get another belt. so when you get the belt you have to think well my supercharger pulley is smaller than stock but my water pump pulley is larger.
    as long as the hassle of getting a belt isnt too much, id probably put it on since i got it for free. nothing wrong with less weight.
  4. #4 Re: should i run my ZZP underdrive pulley?
    Jan 2012
    Philadelphia
    there's 2 belts on a GTP you know that lol the water pump is on the main drive belt so dropping pulley sizes wouldn't have an effect on the belt size for the main drive
  5. #5 Re: should i run my ZZP underdrive pulley?
    Florida
    When i put mine on i didnt need a new belt. Stock belt works good. It seemed to help my car rev easier and a tad of extra pull from down low.
  6. #6 Re: should i run my ZZP underdrive pulley?
    Jun 2011
    Detroit, MI
    If you have it already, its worth it. Here is some info on it: Easy Performance | ZZP Underdrive Water Pump Pulley Testing
    iLoveSpade
  7. #7 Re: should i run my ZZP underdrive pulley?
    Jan 2012
    Philadelphia
    thanks for the info
  8. #8 Re: should i run my ZZP underdrive pulley?
    Nov 2010
    Illinois
    Duh. I do know that. Idk wtf I was thinkin lol dumb ass.
  9. #9 Re: should i run my ZZP underdrive pulley?
    Vancouver, WA
    I like mine, I have a Smoothflow though. I haven't had any kind of issue with it running warmer than before the pulley.
    Slowest 'Cooled Gen V ever
  10. #10 Re: should i run my ZZP underdrive pulley?
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Really guy? Why? Why is it not worth putting on? It's been PROVEN to give you about 5hp and about 5 ft-lbs of torque? He got the damn thing for free, it takes 15 minutes tops to swap it out. So WHY is it not worth it?
    For all your 3800 needs:
  11. #11 Re: should i run my ZZP underdrive pulley?
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    Cause it's a piece of junk... which I will gladly take off your hands for free so it's not taking up any space in your garage.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  12. #12 Re: should i run my ZZP underdrive pulley?
    Jan 2012
    Philadelphia
    lol its small its not taking up any room in my garage
  13. #13 Re: should i run my ZZP underdrive pulley?
    Florida
    put it on guy. no worries its a small gain but it all adds up
    Quote Originally Posted by copgtp View Post
    Cooling > 5 chp.
    Cooling > 5 chp.
    My thoughts exactly.
  16. #16 Re: should i run my ZZP underdrive pulley?
    Nov 2010
    Illinois
    If u have a 180 stat a couple degrees wont hurt
    Orange County, NY
    Because you're really losing that much wp efficiency by using it?
    Aren't u the same guys that advocate the use of a stock t-stat?
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
  18. #18 Re: should i run my ZZP underdrive pulley?
    Jan 2012
    Philadelphia
    i was thinking about getting a colder tstat preferably a 180 deg. i herd of people with 160's whats the down fall or better for a 160 opposed to a 180?
  19. #19 Re: should i run my ZZP underdrive pulley?
    Apr 2008
    Southern KY
    Go 180... 160 is too cold and your heat in the winter will suck. The only reason you should even run a 180* is if you're bumping timing or dropping pullies. If you're stock, then don't even bother.
  20. #20 Re: should i run my ZZP underdrive pulley?
    Jan 2012
    Philadelphia
    Quote Originally Posted by RooK View Post
    i have taylor 8mm plug wires, slp cold air/ram air setup, 2.5 catless dp, plog, glasspack, stock mufflers, soon to have new plugs and drop pulley size after i figure out what size to go with
  1. Underdrive Pulleys for NA v6?
    By Vattic in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-07-2008, 12:15 AM
