Thread: SE sleeper
Results 1 to 5 of 5
  1. #1 SE sleeper
    Mar 2012
    United States
    I am soon going to be swapping the 3.1 in my 2001 GP for a 3.8 Series II. I 'm starting from scratch on the project and it seems pretty "simple". As far as I can tell so far I can use the transmission from the 3.1. I know I'll have to get an ECM and engine wiring harness for the 3.8. Is that really all there is to it? Just wondering if I'm missing anything important. Do I need the 3.8 mounts and will they bolt on where the 3.1 mounts are?
  2. #2 Re: SE sleeper
    Jan 2012
    Philadelphia
    it will prob only be a sleeper with the series II s/c engine they make se's with the 3800 and with a s/c 3.8 you will prob blow up that trans fairly easy im guessing
  3. #3 Re: SE sleeper
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    Been there, done that with a 2000 model SE. While I was at it, I threw in an XP cam, headers, and other goodies. I did it with a whole GTP dropout from Ed Morad, replacing the engine and tranny together.
    Yes, it's pretty simple, you need the L67 harness/ecm. If your throttle cable has a ball on the throttle body end, you'll have to swap it for one with a T from a 3800. I had to do that as well. I can't remember the year cutoffs for the throttle cable. Engine mounts are identical. The 3100 from 2000+ used the same 4T65E as the 3800s, so you'll be fine, just lacking the HD diff. You'll need the ECM reprogrammed for the final drive in the non-HD tranny though, it's not got the 2.93 gears like the GTP has. If you have any questions, just ask and maybe I'll remember. It's been about 5+ years since I did this, and it's still running lol. Mind isn't as fresh as it used to be on all the details though.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  4. #4 Re: SE sleeper
    Jan 2012
    Philadelphia
    nice work!
  5. #5 Re: SE sleeper
    The '01 SE has the same transmission as the GTP...just different gearing and a non-beffy differential.
    It'll be fine if you don't drive like an asshat.
  1. Building a Sleeper
    By gtp20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2011, 01:04 PM
  2. Want to turn my car into a 13 second sleeper!
    By Robroy04gtpcompG in forum Introductions/Noob Questions
    Last Post: 03-07-2010, 12:07 PM
  3. Sleepy Sleeper
    By TDCRacing in forum Off Topic Discussion
    Last Post: 06-21-2009, 03:18 PM
  4. sleeper car
    By Freebeer187 in forum Off Topic Discussion
    Last Post: 11-08-2008, 08:31 AM
  5. Mad Sleeper..
    By snow99dohc in forum Off Topic Discussion
    Last Post: 04-17-2008, 11:22 AM
