Thread: Computer compatibility
Results 1 to 5 of 5
  1. #1 Computer compatibility
    Mar 2012
    Ks
    Would 2000 engine be compatible with 2004 computer? Any info would be appreciated.
  2. #2 Re: Computer compatibility
    Could you give a little more info??
    If you are asking if the 2000 motor itself can be used on a 2004 car/computer then yes it can, if the engines are the same model, like L67/L36 and L26/L32
    But if you asking if the 2004 computer will work on a 2000 car, then no it will not work.
  3. #3 Re: Computer compatibility
    Mar 2012
    Ks
    OK after checking vin #'s, don't look good, but we are trying to put 2004 L26 SFI engine into 2000 car with L36 MFI engine. Could we put 2004 computer, along with engine & tranny in 2000 car
  4. #4 Re: Computer compatibility
    Yes, but it would require a little bit of work.
  5. #5 Re: Computer compatibility
    To many things will be different, its not possilbe it my mind.
    The pcm will not work with the wiring in the 2000 car. Also 04+ are DBW, 97-03 use throttle cables.
    Your best bet is to take the motor as longs its a NA and swap top ends and mate it to your transmission in the 2000 car.
    Or just find another L36 and 3.29 GT trans and swap them.
  1. SE/GT Compatibility
    By ShadowSwept in forum General Tech Discussion
    Last Post: 03-31-2012, 12:55 PM
  2. MAF compatibility
    By benner in forum General Tech Discussion
    Last Post: 06-13-2010, 05:34 PM
  3. DP and Powerlog Compatibility
    By Bedwards in forum Turbo
    Last Post: 11-22-2009, 05:21 PM
  4. Compatibility
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-19-2009, 02:34 PM
  5. 2DR / 4DR seat compatibility
    By StreetChariot in forum General Tech Discussion
    Last Post: 03-28-2009, 11:45 AM
