Thread: NEED ADVISE for 1994 Grand Prix SE 3.1L Inner Tie Rod Replacement
Results 1 to 9 of 9
  1. #1 NEED ADVISE for 1994 Grand Prix SE 3.1L Inner Tie Rod Replacement
    Mar 2012
    Vancouver,BC,CANADA
    Hi Everyone,
    The inner tie rod needs to be replaced on 94 Grand Prix SE 3.1L. I took out the outer rod from the inner. I got the special tool to remove it, however, it does not work. The inner tie rod does not have a hex on it. The outer part of the inner rod is rotates on it self. I would be appriciated if anyone gives me an advise.
    Thank you,
    Kanki
  2. #2 Re: NEED ADVISE for 1994 Grand Prix SE 3.1L Inner Tie Rod Replacement
    it won't have a hex on it it'll have 2 flat spots for the tool to hook on. There are also different sized inner tie rod tools as well so make sure you have the right one.
  3. #3 Re: NEED ADVISE for 1994 Grand Prix SE 3.1L Inner Tie Rod Replacement
    Mar 2012
    Vancouver,BC,CANADA
    Thanks dsmuts,
    It does not have flat spots either. Any suggestions, thanks,
  4. #4 Re: NEED ADVISE for 1994 Grand Prix SE 3.1L Inner Tie Rod Replacement
    take a pic if possible. if nothing else try a pipe wrench.
  5. #5 Re: NEED ADVISE for 1994 Grand Prix SE 3.1L Inner Tie Rod Replacement
    Dec 2011
    united states
    lisle makes another special inner tie rod tool for the tie rods that do not have anything to grab on to; or just put a pipe wrench on it.
  6. #6 Re: NEED ADVISE for 1994 Grand Prix SE 3.1L Inner Tie Rod Replacement
    Mar 2012
    Vancouver,BC,CANADA
    Thank you all for helping me out. The inner tie rod on my vehicle is covered some type of a yellow ring, which rotates on it. I did not know that one comes out. I will try to take that one out first. I will post the result.
    Thank you again.
    Kaan
  7. #7 Re: NEED ADVISE for 1994 Grand Prix SE 3.1L Inner Tie Rod Replacement
    under that is the 2 flat spots i was talking about. that ring doesn't really need to go back on if you don't want it to.
  8. #8 Re: NEED ADVISE for 1994 Grand Prix SE 3.1L Inner Tie Rod Replacement
    Mar 2012
    Vancouver,BC,CANADA
    Thanks for all the advise.
    I was able to took it off yesterday. I put the new part and the remaning parts. Now I have to take it to the shop for balancing.
    I have one more question. I screwed the new rod to approximatley where the old one was. When the stering is showing forward the vehicle pulls to the right side. My question is if I put the new rod off from the old place, it can be still balanced witout removing and adjusting the outer tie rod?
    Thank you,
    Kaan
  9. #9 Re: NEED ADVISE for 1994 Grand Prix SE 3.1L Inner Tie Rod Replacement
    The inner needs to be as tight as you can get it and as for the outer they don't need to remove it to do an alignment.
  1. New 1994 grand prix se owner Nj
    By jrzygp in forum Introductions/Noob Questions
    Last Post: 05-05-2012, 12:19 AM
  2. Need Advise for 1994 Grand Prox SE inner tie rod replacement
    By Kanki in forum General Tech Discussion
    Last Post: 03-09-2012, 03:42 PM
  3. 1994 grand prix gtp hid issues not fitting
    By gino101 in forum Audio, Security & Visual Electronics
    Last Post: 12-22-2011, 09:38 AM
  4. 1994 Grand Prix SE Front Modification Possible?
    By KobAil in forum Visual/Body Modifications
    Last Post: 01-09-2009, 08:38 AM
  5. 1994 Grand Prix Transmission Help!
    By mfalk22 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-25-2008, 11:41 AM
