Thread: Best Engine Degreaser
Results 1 to 19 of 19
  1. #1 Best Engine Degreaser
    SE Level Member Burley117's Avatar
    Nov 2011
    Kalamazoo, MI
    Does any body know of a good Engine Degreaser? Something strong, but not so potent that it could take paint off of the engine bay area. I used to have this stuff that my body shop guy recommended-came in an aluminum can and smelled like mineral spirits. Worked really well for grease and getting tar off of paint...just don't know the name.
    Any thoughts?
    06 Grand Prix, 01 Grand Prix GT, 98 Grand Prix GT, 98 GrandPrix GTP
  2. #2 Re: Best Engine Degreaser
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Awesome
  3. #3 Re: Best Engine Degreaser
    new britain, ct
    purple power!
    07 Black GXP.
  4. #4 Re: Best Engine Degreaser
    Panama City Beach, FL
    Quote Originally Posted by Burley117 View Post
    Any thoughts?
    That's your run of the mill engine degreaser. It sucks. Purple Cleaner all the way.
    From the makers of release all : bio degradable parts cleaner...
  6. #6 Re: Best Engine Degreaser
    i use foamy engine de greaser, made by GUNK i think. stuff works real good, keep it off the cars paint tho, it removes the wax you may have on the car.
    when i first got my car it was a real mess, so i drove up on car ramps, and sprayed it all underneath and then sprayed the top and sides, let it sit, then hosed it down, from the top and bottom. used 2 large cans. you can use a paint brush on thick grease build up areas as well.
    i also like to use a air compressor to blow dry it after im done, but you can make due with out it.
  7. #7 Re: Best Engine Degreaser
    Buffalo
    its simple, and green
  8. #8 Re: Best Engine Degreaser
    Feb 2010
    TN
    Citrus power
  9. #9 Re: Best Engine Degreaser
    HUDSON
    The best that I have found is "SIMPLE GREEN" for de-greassing anything, with the exception of wheel bearing greease. Work great to
    for cleaning hands too. Smells good, doesent hurt paint, no bad fumes, non-flammable.
  10. #10 Re: Best Engine Degreaser
    Nov 2011
    NY
    Simple Green +1
  11. #11 Re: Best Engine Degreaser
    Nov 2011
    Kalamazoo, MI
    Sounds like Simple Green and Purple power seemed to be the highest regarded....maybe if I combine them I'll get something awesome...Simple Brown? lol
  12. #12 Re: Best Engine Degreaser
    I've used Simple Green, Simple Green Automotive, Purple Power and some commercial degreasers. They all work decently until the grease is 1/4" or more thick. That will always take a couple applications.
    or....you could just pressure wash and be done. That is my current method of choice with any degreaser
  13. #13 Re: Best Engine Degreaser
    new britain, ct
    yeah i pressure wash and use a little bittt of purple...ask bill, 8 months after i washed it he looks at my bay and says "matt, thats the cleanest 3100 ive ever seen"
    07 Black GXP.
  14. #14 Re: Best Engine Degreaser
    Usually they are ugly greasy motors Matt... It's only been two years for mine.
  15. #15 Re: Best Engine Degreaser
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    I've had great luck with Simple Green. It doesn't leave a film behind like Purple Power does. Also, as someone said, you can use it to clean your hands. I'd spray it all over my arms, then hose them off. Do it with any other degreaser and you'll be screaming at the burning sensation from your pores. lol
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  16. #16 Re: Best Engine Degreaser
    Jan 2012
    Philadelphia
    or you can buy the degreaser you put in your pressure washer and have x2 power in faster time!
  17. #17 Re: Best Engine Degreaser
    when i worked at a garbage company, every week we aka me the driver, or the driver of what ever truck, had to de grease, and then wash the whole truck bumper to bumper and under the hood, im talking frame axle's engine everything.
    we had zep de greaser in a 55 gal drum, pumped it into a lawn pump sprayer, sprayed every thing except the painted cab, then washed it down with a hottsy power washer.
    then we had a another can full of commercial powdered soap, yeah you know it, a stick with a brush on the end with soap on everything again. then rinsed with just hose. if done the way the boss wanted, it took an hour to wash it.
    [IMG][/IMG]
  18. #18 Re: Best Engine Degreaser
    I've wanted to try this stuff we have my work but I'm afraid it would eat something, cuz if you get it on your hands it eats your skin, it works really well for cleaning ovens
  19. #19 Re: Best Engine Degreaser
    GT Level Member Pontiac Man's Avatar
    Sep 2011
    Decorah IA
    When I used to to clean construction equipment we had this stuff we would spray in the engine bay and it would take the paint off. The first time I used it I got it on my hand and did not think much of it till I thought my hand was melting off. Most of the equipment had a few inches of oil and dirt on the bottom of the motors and that stuff would eat it right up.
  1. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
