Thread: The GTP Fire
Results 1 to 14 of 14
  1. #1 The GTP Fire
    Wichita
    Finally got around to fixing my laptop so I uploaded a bunch of pix. Here's some pix of the damage from my recent engine fire.
    You can see the melted fuel line resting atop the s/c
    Oops its upside down...
    Trashed BBV among other things
  2. #2 Re: The GTP Fire
    scary
  3. #3 Re: The GTP Fire
    Dec 2011
    Grand Prairie, Tx
    What exactly happen?
  4. #4 Re: The GTP Fire
    Wichita
    Ruined fuel pressure gauge
    In teardown process
    Had to repaint s/c & valve covers
  5. #5 Re: The GTP Fire
    SE Level Member rodneypierce's Avatar
    Jan 2012
    Cedar rapids, IA
    Quote Originally Posted by jwjones View Post
    If I remember reading correctly, the fuel line popped off.
    1998 GTP. Stock.
  6. #6 Re: The GTP Fire
    Wichita
    What exactly happened? Nearest I can figure the pressure in the fuel line made the sending line pop off and spew gas everywhere.
  7. #7 Re: The GTP Fire
    Wichita
    Soo if anyone has or knows someone with a fuel line or evap line(the one that connects to the evap cannister then the TB) hit me up those are the only parts I still need.
  8. #8 Re: The GTP Fire
    fuel lines go back to the tank. You'd probably be best wtih an AN setup. That way there's threads and the line can't pop off. Wondering if this is common with zzp rails. Bill Stewarts car did the same.
  9. #9 Re: The GTP Fire
    Wichita
    ^^^thats what farnsworth recommended I do.
  10. #10 Re: The GTP Fire
    Wichita
    Finally got her finished! Here's a breif list of what had to be replaced;
    Master Cylinder
    Fuel lines
    BBV
    MAF
    FPR gauge
    Injector Orings
    S/C gasket
    Wiring Harness
    S/C tensioner
    Alternator
    Tensioner pulley
    Accessory belt
    S/C belt
    Spark plug wire #1
    Vacuum line
    Wiper fluid bottle neck
    And of course I repainted everything & I'm still finding extinguisher foam in places. Since it's done now I'll probably sell it soon.
  11. #11 Re: The GTP Fire
    GT Level Member ShadowSwept's Avatar
    Kentucky
    Call me a noob if you will, but what is that rear bar between the strut towers, and why doesn't my car have it?
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  12. #12 Re: The GTP Fire
    Ohio
    its a strut tower brace, came stock on bonnes, regals and park ave's...you can get them on the aftermarket. this is the cheapest option of them all. but they all work the same imo.
  13. #13 Re: The GTP Fire
    40-15'30'' N 085-40'33'' W
    Its a strut tower brace. They help with body flex. They dont come with them from the factory.
  14. #14 Re: The GTP Fire
    Quote Originally Posted by 99pgpgt View Post
    Came stock on nearly everything but the "sportscar". Bonne and PA were too big to fit to a W body. Many Regals had then stock, Impalas also had them stock. A JY typically charges about $10 for one.
  1. fire in the sky
    By Scottydoggs in forum Off Topic Discussion
    Last Post: 09-26-2011, 12:39 PM
  2. my ass is on fire
    Last Post: 07-02-2011, 05:06 AM
  3. #1 Cyl Mis Fire
    By 88ironduke in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 07:58 PM
  4. my a$$ is on fire...lol
    By cojo in forum General Tech Discussion
    Last Post: 05-10-2009, 09:32 PM
gtp
