Thread: Might buy grand prix. help on engine fire!
Results 1 to 20 of 36
  1. #1 Might buy grand prix. help on engine fire!
    Vail, CO
    so i found a couple grand prixs that look real clean for a fair price. im not a car modder, i like the cargo room and anti lock brakes. the years are 97 and 00 and both have like 150,000k. these seem like decent cars except for when the FREAKING CAR CATCHES FIRE after you park it and leave. looks like it was because oil leaks onto the exhaust manifold and ignites? ive been reading horror stories about this and really would like to know it this is preventable as this is my only qualm about buying the car. i also would be getting the 3.8 non supercharged, maybe a 3.1 if i can find one. help please?
  2. #2 Re: Might buy grand prix. help on engine fire!
    I go for the 00, not a fan of 97's personally.
    Get new valve cover gaskets and all those worries will be flushed down the drain.
  3. #3 Re: Might buy grand prix. help on engine fire!
    new britain, ct
    these cars catching on fire is actually pretty rare. i mean any car is susceptible to an engine fire if theres an oil leak. if its a big concern changing your valve cover gaskets should take care of it. 97 is an odd year, i would stay away. and the 3.8 will be a more reliable platform. not even for modding but ive seen those engines last foreverrrr.
    07 Black GXP.
  4. #4 Re: Might buy grand prix. help on engine fire!
    GXP Level Member Zef_66's Avatar
    PA
    Don't let these guys fool you. There is nothing wrong with 97s. I've had 2 and would buy one again. Not a thing wrong with them.
    But like they said, the engine fires are from oil leaking onto the exhaust manifold from the valve covers. Change the valve cover gaskets and you are good to go.
    2001 GSE
  5. #5 Re: Might buy grand prix. help on engine fire!
    Vail, CO
    reliability is my main concern here. my 94 saturn's transmission is gone and its running on borrowed time. the 97 is $2200 and the 00 is $2600. id rather spend less and get the 97 so i can change the gaskets
    you guys know how much a shop charges to change the valve cover gaskets? if its not hard i could probably to do myself. im no car mechanic but im pretty industrious
  6. #6 Re: Might buy grand prix. help on engine fire!
    its not hard to do, you could easily take care of it yourself.
  7. #7 Re: Might buy grand prix. help on engine fire!
    PA
    Agreed. They are not hard. If you can turn a wrench even a little, you can do it.
    2001 GSE
  8. #8 Re: Might buy grand prix. help on engine fire!
    new britain, ct
    the only reason why i say watch out for a 97 non supercharged is because the 97 non S/C came with a 4t60 transmission...not the 4t65 (upgraded transmission) that 98 plus got. someone correct me if im wrong.
    07 Black GXP.
  9. #9 Re: Might buy grand prix. help on engine fire!
    Stay away from the 3.1 at all costs
  10. #10 Re: Might buy grand prix. help on engine fire!
    Texas
    Damn 1997 haters LOL. I'm changing my sig.
    85 Corvette
    01 TA
    03 Z06
  11. #11 Re: Might buy grand prix. help on engine fire!
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    the issue that caused the fire is on recall so if you can get the VIN numbers off both cars, you should be able to go to the dealership and take a look to see if they were replaced. Another thing you want to check out is if the lower intake manifold job was replaced. I am handy and did the job myself but i went to the dealership to get a quote just for sh!ts and giggles and they told me 675 bucks NOT including what i did by myself which was replace the valve cover gaskets while i had it apart, paint my valve covers red, and replace my thermostat, and do an oil change with synthetic oil. all which is super easy while doing the job and having everything ripped apart. This all cost almost 200 bucks. If you are not a mechanic and cant do a tune up and/or feel uncomfortable going further than that then please dont try it. you do it wrong and those new gaskets will leak.
    i personally think that the 2000's are nicer. mechanically wise for the most part they are the same. 150k is a lot for a 2000 if you consider that 10-15k a year is the average range of mileage. and i also prefer the 3.8's over the 3.1's and 3.4's not that i think those are bad just like the 3.8 much more.
  12. #12 Re: Might buy grand prix. help on engine fire!
    Quote Originally Posted by bps02gtp View Post
    They should change your oil after a lim job anyway and the 3.1 and 3.4's are horrible engines 3800 all the way.
  13. #13 Re: Might buy grand prix. help on engine fire!
    new britain, ct
    3.1's arent horrible at all. 3.8 is better, but 3.1's arent bad at all. just change the LIM gaskets and youre fine lol.
    07 Black GXP.
  14. #14 Re: Might buy grand prix. help on engine fire!
    GrandPrix Junkie
    St. Louis
    Even if you change the valve cover gaskets to try and avoid a fire, I suspect that the real culprit was the quick disconnects at the fuel lines, which if disturbed even once have a way of leaking and causing a potential fire hazard. I had to replace the o-rings on mine when I swapped motors and its been all good since. And get Fel-Pro valve cover gaskets AND grommets and call it a day. Don't cheap out on those.
    The recall was nothing more than them replacing the front plug wire guide w/ an updated version that lead the oil leak to a different location. A crappy bandaid to avoid law suits. FWIW, I'm still running my stock wire guide up front, but have Fel-Pros in place and have yet to see a bit of oil leak.
    I personally would go for the 00. The 97's were an odd duck, as well as the 03's. Not hatin on the 97 guys, just personal opinion. And yes, change the LIM gaskets (even on the 3.8's) to the aluminum ones, which all 97-mid-04's suffer from. And I prefer the 3800 to the 3100 any day.
    And yes, the 97 GT had the weaker 4T60 vs the 98+ 4T65E (or the 4T65E-HD for the GTP).
    I'd walk up w/ $2,400 cash if the 00 is clean and see what they say. Always be ready to walk away. They made a bazillion of these cars so another good one isn't hard to find. I have 265K on my 00 GT and haven't had any major issues with it (aside from me grenading the motor on accident, but was my fault). Still looks better than 80% of the cars on the road today and gets good mileage.
    There are a few things that I would check out on either car before buying that are known weak points of these cars. Trans., milky oil, coolant color, etc. If you're not overly familiar with this then just ask and we can be more specific.
  15. #15 Re: Might buy grand prix. help on engine fire!
    Vail, CO
    well i just checked out the 97. its an SE V6. The seller owns a body shop. he buys cars then turns them over for a profit i guess. this one has been his daily since july because he likes it. it looks and drives fine. he put in the interior of the gtp in this car so now its black leather. the low coolant light was on, he says the car goes through about a soda cans worth of coolant a month but also said his mechanics couldn't find any leaks. he said the light comes on even of the coolant level is like a few centimeters below the full line. the coolant has to go somewhere right? it doesn't just evaporate.
    under the hood was normal dirt and grime for a 90's car. there's nothing i can say about it anyway, the saturn's been the only car ive ever owned. the car shifts just fine. is the coolant thing a problem? any red flags? i was planning on getting a pre-purchase inspection by a 3rd party mechanic before i buy it anyway just so i know what the cars about.
    edit: the engine said 3800 on it. i assume its a 3.8L
  16. #16 Re: Might buy grand prix. help on engine fire!
    the lower intake manifold gasket is leaking if you do it yourself it's about a $150 fix with fluids and all. If you take it to a shop it's about $900
  17. #17 Re: Might buy grand prix. help on engine fire!
    Vail, CO
    damnit. i assume thats a big problem that cant go un repaired? if theres some comprehensive guide floating around online then cool. but otherwise i dont trust myself doing car repairs
  18. #18 Re: Might buy grand prix. help on engine fire!
    new britain, ct
    yeah its a big deal. judging from how long its been leaking i would honestly stay away from that one.
    07 Black GXP.
  19. #19 Re: Might buy grand prix. help on engine fire!
    Since you said it's an se i assume it's a 3100 but if it had the 3800 it's 1000X's easier to do the lim gasket. I personally wouldn't own a 31/3400 because they are such a pain to work on.
  20. #20 Re: Might buy grand prix. help on engine fire!
    Texas
    Quote Originally Posted by Fox View Post
    It's not that bad, just seems like a lot more work than it really is. Click the link in my sig. I have pictures when I replaced mine.
    85 Corvette
    01 TA
    03 Z06
  1. Fourth brake light/Line of fire for a Grand Prix?
    By mngtp in forum Visual/Body Modifications
    Last Post: 12-29-2011, 06:57 PM
  2. My Grand Prix cranks, but doesn't fire
    By Moriachik in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2011, 07:02 PM
  3. Fire Lights/Siren in '01 Grand Prix
    By iceman977th in forum Visual/Body Modifications
    Last Post: 11-17-2010, 08:55 PM
  4. craigslist car $250 engine fire
    By 16MustangVet in forum General Tech Discussion
    Last Post: 04-14-2010, 03:54 PM
  5. Engine Fire
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2009, 12:26 PM
