Thread: Might buy grand prix. help on engine fire!
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: Might buy grand prix. help on engine fire!
    GT Level Member Ravenwald's Avatar
    May 2011
    Fort Myers, FL
    You'll find that most GP repairs have guides for them. If not on this forum, then Club Grand Prix! Your online Grand Prix & G8 resource.
    Also, as a forethought, if you get a Grand Prix (97-03), make sure you scroll through the quality issues guides and eliminate any future problems. For instance, the annoying little gutter of a drain that sits over your cabin intake. Trust me, you don't want water in your floorboards.
  2. #22 Re: Might buy grand prix. help on engine fire!
    Vail, CO
    decided to forego the '97. i dont want to deal with any leaks right off the bat.
    i found a 2002 grand prix GT 3.8 for $2500. 180k miles. gonna check that one out instead
  3. #23 Re: Might buy grand prix. help on engine fire!
    Feb 2010
    TN
    Mine ran fine until the recall after GM fixed it it ran horrible 3 weeks later it caught fire thank god it was in my driveway and I have the hood up I could put it right out (was standing next to the garden hose) took 6 months to get them to fix it they would not admit fault in the meantime I fixed it they finally agreed to trade a paint job to stay out of court
  4. #24 Re: Might buy grand prix. help on engine fire!
    SE Level Member Dragon1972's Avatar
    You are so wrong...engine compartment fires on these cars is fairly likely, according to the TSB's and recalls
    Master Certified Automobile Technician
    1997 GP GT-SC
  5. #25 Re: Might buy grand prix. help on engine fire!
    The reason for the fire was the cooling fan circuit
    1997 GP GT-SC
  6. #26 Re: Might buy grand prix. help on engine fire!
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    That's the same price u would've paid for the others but this has 30,000 miles more. 180k is extremely a lot especially for a 10 year old car.
  7. #27 Re: Might buy grand prix. help on engine fire!
    Quote Originally Posted by bps02gtp View Post
    180K miles is nothing for a 3800 mine has 211K on it right now.
  8. #28 Re: Might buy grand prix. help on engine fire!
    Quote Originally Posted by Fox View Post
    98-08's can still suffer from valve cover gasket leaks and the remaining powersteering and trans cooler lines can still leak.
    Any 3800 without metal framed LIM gaskets is prone to failure.
    Any L36 is prone to UIM failure. aftermarket replacements are less prone to failure.
    Quote Originally Posted by Dragon1972 View Post
    Do you have numbers on the failures?
    LIM gasket failure is likely, but i never see any in for repair. Only 60* GM's for LIM and head gaskets.
    Does that make my sample accurate?
    The cooling fan circuit is not addressed in the recall.
    The valve cover gaskets in supercharged applications are replaced and the spark plug wire retainers are replaced with a design which is designed not to hold oil.
  9. #29 Re: Might buy grand prix. help on engine fire!
    Vail, CO
    ok this is going to be the last car i ask about. if this one has problems too im just gona look for other brands.
    98 GTP. 145k miles. $2400. assuming its in great mechanical condition. any potential problems i should be concerned about with the car aside from the valve cover gaskets?
  10. #30 Re: Might buy grand prix. help on engine fire!
    Everything that can fail on any car in the current market.
    The only serious failure points are the valve cover gaskets and LIM gaskets.
    Both of which aren't serious repairs if you can perform the repair yourself.
    No special tools are required and it should be easily accomplishable within the constraints of a weekend.
  11. #31 Re: Might buy grand prix. help on engine fire!
    That's not to bad of a deal on the gtp I'd buy it for that. Just check out the rocker panel and strut towers in the trunk for rust and pull the oil cap off the motor and see if it looks milky on the bottom of it that'll mean the lim gasket needs replaced. That is pretty simple job on the 3800 though.
  12. #32 Re: Might buy grand prix. help on engine fire!
    Vail, CO
    the GTP is in excellent condition. ill get a mechanic to check it before i buy it. so i plan on living in the mountains in a few months. i don't really plan on driving a whole lot, especially in the snow. but will cold weather / snow negatively affect the supercharger in any way? in fact what does negatively affect a supercharger and how can i prevent it from going ape sh1t?
    It will make more power in the cold, that's about it
  14. #34 Re: Might buy grand prix. help on engine fire!
    LA
    Idunno if someone posted it already but there was a safety recall. When you register it they will send you something in the mail telling you you can go to the dealership and get a new rocker cover for free or something. I went, but they told me that because I had an aftermarket manifold i didn't have anything to worry about
  15. #35 Re: Might buy grand prix. help on engine fire!
    Nov 2010
    Illinois
    I'm very aware of the mileage a 3800 can reach but that's if u know specific mechanical history. U don't know how much it was beat on or if their oil changes were on time. There's a lot of miles which means its probably highway. Did they travel at 90-100 mph the whole time they were on the highway?
    Not only that but u have a 98 and that's a 4 year difference.
    Fox this new gtp sounds like a great find. Its in ur price range and it has average mileage for its age. For the most part there is nothing specific about a year that u should avoid unless u have certain preferences. All 97-03 gps are gonna have the lim and valve cover issues that we mentioned. Like I said before if ur not familiar with a tune up u probably shouldn't tackle these jobs. Yes they are easy but u at least have to understand how to do some things to the engine before u do a big one. If ur not up for the job and don't wanna spend 500 to 900 bucks for the repair, then don't consider it.
  16. #36 Re: Might buy grand prix. help on engine fire!
    Vail, CO
    i bought the gtp
    runs good. mechanic didn't find any real problems with it. had a small oil leak i think, said it was normal for cars w/ 150k. when i was driving home the low coolant light came on for 5 seconds then turned off. the engine bay is pretty dirty and grimy. want to get a steam clean for the engine bay so i can start familiarizing myself with engine components. anyone know what the cost is for that?
    and i have to get the alignment fixed cuz the car pulls to the left. the coolant was yellow / golden colored so i dont think it has dexcool in it, but im gonna get the coolant changed just in case
  1. Fourth brake light/Line of fire for a Grand Prix?
    By mngtp in forum Visual/Body Modifications
    Last Post: 12-29-2011, 06:57 PM
  2. My Grand Prix cranks, but doesn't fire
    By Moriachik in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2011, 07:02 PM
  3. Fire Lights/Siren in '01 Grand Prix
    By iceman977th in forum Visual/Body Modifications
    Last Post: 11-17-2010, 08:55 PM
  4. craigslist car $250 engine fire
    By 16MustangVet in forum General Tech Discussion
    Last Post: 04-14-2010, 03:54 PM
  5. Engine Fire
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2009, 12:26 PM
