Thread: FYI - Don't overfil your tank.. When it stops, consider it full.
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Jun 2011
    Detroit, MI
    Quote Originally Posted by SnowFlake View Post
    IDK about you guys, but when I'm "filling up" after it clicks, I can put another 4 gallons in until it's topped off.
    You might have a bad fill neck or something, mine is usually past F when it clicks.
    iLoveSpade
  2. #22 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    SE Level Member midrange's Avatar
    Belleville, Ontario
    It doesn't leak as far as fuel splling out.
    I have always been one to fill right to the top, even some times over filling and spilling. I've never heard of the issue before, and to be honest, I don't think it is a issue at all as the light never came back on after they erased the code.. It came up on their computer as a large evap leak.. They cleared the code and its been good since.. I must have not screwed it on tight enough.
    ON previous vehicles, I always got a check engine light or SES light when i had issues with gas cap, but on the GP i never got a light. Just the screen saying check gas cap.
    2004 Grand Prix GT1
  3. #23 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Dec 2011
    united states
    Quote Originally Posted by midrange View Post
    Hey guys and gals
    So yesterday I was driving the car and the check gas cap light came on.
    I never had the light come on before
    What the hell is a check gas cap light? I haven't had the light come on before either because I've never heard of it haha. I've always been curious, is there something inside the gas tank that causes the pump to stop when the tank is full? I've just never understood what causes the pump to click and stop pumping.
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    Quote Originally Posted by Bjorn20 View Post
    Its built into the pump handle.
  5. #25 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    SWPA
    From how stuff works
    As the gas level in the tank rises, the distance between the dispenser nozzle and the fuel grows smaller. A small pipe called a venturi runs alongside the gas nozzle. When the end of the venturi pipe becomes submerged in the rising gas, it chokes off the air pressure that holds the nozzle handle open and shuts down the flow of gas. Unfortunately, this shutdown can sometimes happen before the tank is full as the rapidly flowing gas backs up on its way into the tank. This can cause the gas handle to spring open before pumping is complete, leaving the annoyed customer to squeeze the handle again and risk the possibility of overflow. Pausing briefly will allow the gas to continue into the tank and the pump nozzle to start pouring gas again.
  6. #26 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Belleville, Ontario
    It comes up on the DIC as a message saying Check Gas Cap. Only on the 04+.
    2004 Grand Prix GT1
  7. #27 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    Quote Originally Posted by NegativeOne13 View Post
    I do that all the time... but also figure in the discount. If you pay w/ cash you get a 5% discount.
    That is not always true. I really hate to go in to the store to pay for my gas, I dislike prepaid. Anyway, at this gas station I went to, they had gas for 3.05 cash (a while ago) but there was a lot of customers in the store and I didn't want to waste time. So I used my bank card and guess what?... I paid 2.96!
  8. #28 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Nov 2011
    south carolina
    I've had to replace charcoal canisters and related plumbing due to customers packing thier fuel tanks but I can't recall it ever happening on a grand prix.
  9. #29 Re: FYI - Don't overfil your tank.. When it stops, consider it full.
    Banned
    CT
    Quote Originally Posted by Hippo Machine View Post
    Bad fill neck? If I don't top it off it's past "F" too... but when I do top it off, I can drive about 150 miles before it goes below "F".
  1. Full tank of fuel gauge floats between full and empty.
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2013, 06:17 PM
  2. new pcm. hard downshift from 2nd to 1st at stops??
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2010, 07:10 PM
  3. Eibach's and the bump stops
    By FuglyGTP in forum Brakes/Suspension/Chassis
    Last Post: 08-18-2010, 12:18 PM
  4. better gas mileage when tank is full/almost full
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2010, 09:53 AM
  5. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
