Re: Can't break free front axle nut.
Hippo Machine
humming noise
When you don't know what you are talking about its better you stay out of the conversation. Again, neither one of those things would cause a "humming noise"
Do you have even wear on the tire tread?
stealthee
First, I said just a thought.
Second, yes it can.
Third, if you don't have anything to say that would help the OP then get out.
When my wheels were out of alignment I had horrible vibration and A HUGE HUMMING NOISE. So yes they can make that noise. And also my friend's truck hums because of the tire tread so essentially anything can cause it. We are here to help people as hippo said. Man, oh man cccc ccan't we all jj-just get along?
Goodyears = problem
but anyway, check that other side and see whats up.
Hippo Machine
Second, yes it can.
First, you're wrong
Second, no it can't
Third, I posted advice earlier
04BlackComp_G
When my wheels were out of alignment I had horrible vibration and A HUGE HUMMING NOISE. So yes they can make that noise. And also my friend's truck hums because of the tire tread so essentially anything can cause it. We are here to help people as hippo said. Man, oh man cccc ccan't we all jj-jut get along?
Sorry, but your bad alignment didn't cause the humming, something else did. I had my Stealth WAY out of alignment from having the front end apart several times and never once had a humming noise.
stealthee
First, you're wrong
Second, no it can't
So you want to sit in my car and I re-create the issue and you tell me otherwise? You weren't there to experience it so don't call on something that YOU don't know about. My ears and my ass know what I heard and felt and when I put the stockers back on it solved the problem. Every car is different pal. But then again, I'm a dumb ass and absolutely no clue what I'm talking about.
stealthee
First, you're wrong
Second, no it can't
Saying to get bigger balls and muscles is not relevant advice..
Just because your Stealth never hummed from alignment, doesn't mean someone else cant. Stop being an ass.
Out of BALANCE wheels can cause vibration, anyone with half a brain knows that, but a bad alignment will NOT cause a humming noise. There is a difference between vibration and humming.
Hippo Machine
You obivously didn't read because I did mention that sometimes they are overly tight since I did lift a car once from an over-tight axle nut. And my car was SEVERELY out of alignment and didn't hum. I have driven several cars that were out of alignment and not one of them hummed. There is nothing to cause a humming noise when its out of alignment so NO it wont cause a hum. I've been working on cars since before you were born so I think I know a little more than you.
if the front end is out enough, the tires could hum. but thats really out of whack.
Hippo Machine
Stop contradicting yourself, dumbass.
Where did I contradict myself DUMBASS?
A rubbing noise, and a humming noise, IS NOT A VIBRATION.
Hippo Machine
have the wheels been balanced and aligned recently? just a thought.
stealthee
Neither one of those issues would cause a rubbing noise.
stealthee
stealthee
How about all you ****ing nancys stop ****ing fighting. The internet is too serious to be serious.
Just go on, I was trying to help and you butt in saying we're stupid. Just leave.
Hippo Machine
Again, a VIBRATION, is not a humming. Huge difference.
Fivefingerdeathpunch
make sure you torqued the new wheel bearing to 118 ft lbs. (axle nut)
Or just stand on the bar like many people lol
Hippo Machine
I help people with real world advice, and knowing what I am talking about. You guess, and usually guess wrong. I think I'll stay.
****ing celine dion!!!!!! *****esss!!!!!
