Thread: 4T-60 to 4T-65e HD swap
Results 1 to 13 of 13
  1. #1 4T-60 to 4T-65e HD swap
    SE Level Member ImColeTrickle's Avatar
    Apr 2011
    Athens, Alabama
    Since everyone says the 4T-60 is garbage for modding I am staring to look in to used transmissions that I can rebuild overtime. I was just wondering if a 4T-65e HD can be swapped into a 1997 Grand Prix GT with just a tune for the gears. And does it have to be from a 97 GTP?
  2. #2 Re: 4T-60 to 4T-65e HD swap
    SE Level Member Mater's Avatar
    Feb 2010
    my house
    you need the engine bay harness and computer from a 97 GTP for it work the 4t60 and 4y65 have compleatly diffrent wiring. not sure how it would work with a L36 as the only two cars i know of that have done this where either a top swap or a compleat L67 swap
    the 97 GT i am buying has this swap done but for some reason the overdrive is not working trying to figure this out.
    the other 97 GT that had this swap done wroked with no issues
    But why make it an SE?
    99 Grand Prix SE coupe:
    junk yard trans junk yard engine and junk yard turbo
    03 Silverado 2500HD ECSB: 6.0 4x4 01 Aurora:​ 4.0L vin number 2
  3. #3 Re: 4T-60 to 4T-65e HD swap
    GT Level Member Fraschy's Avatar
    Aug 2011
    Sheboygan, Wisconsin
    Wait that doesn't make sense..4t60e isn't neccesarily OBD1..because they made these trannies in 1996 yet, which was OBD2. But if you have a 1997 you have a 4t65e.
    1994 Grand Prix GTP - Dead
    1995 Grand Prix SE Coupe
    2007 Pontiac Torrent
  4. #4 Re: 4T-60 to 4T-65e HD swap
    Aug 2011
    You have a 1997 GT? Then you should have the 4t65e. 4t60e is OBD1, last year with that was 1995 for the Grand Prix. The HD is for the supercharged engines. And I may be wrong, but if you are going to swap, I think you will be needing one from a 1997, since I think the wiring may be different in the 98+.
  5. #5 Re: 4T-60 to 4T-65e HD swap
    Feb 2010
    my house
    1997 was a bastared year only year the second gens had the 4t60 and only in the SE and GT
    here is a thread on antoher board about doing the swap. but like i said we are tring to figure out why there is no overdrive on this car when the other swapped car did not have this issue
    http://www.gpona.com/forums/transmis...gt-t24345.html
  6. #6 Re: 4T-60 to 4T-65e HD swap
    Aug 2011
    Well that clears up exactly why 1997 was so different from the others. lol.
  7. #7 Re: 4T-60 to 4T-65e HD swap
    Feb 2010
    my house
    and why it is mostly unloved lol
    the ABS system and traction control is also special to 97 as well as a few other things
  8. #8 Re: 4T-60 to 4T-65e HD swap
    Apr 2011
    Athens, Alabama
    so will the 4T-60 function with boost?
  9. #9 Re: 4T-60 to 4T-65e HD swap
    Feb 2010
    my house
    for a little wile. the green 4dr in that thread i posted killed 2 4t60s and one was built with stonger parts why it got the 4t65 swap to begin with
    first death was burnt cluches
    second death was a busted input shaft
  10. #10 Re: 4T-60 to 4T-65e HD swap
    Apr 2011
    Athens, Alabama
    so the way I understood that thread you posted is that I can swap to like a 99 style harness, pcm, and trans, I just wont have ABS or traction control
  11. #11 Re: 4T-60 to 4T-65e HD swap
    You don't need a harness. Just the connector and 5 more pins to add to the pcm connector. 97 wasn't such a bastard year. 97 was the first year of the 4T65 on the S2 SC. 96...that was a bastard year for the SC S2 and 4T60, the pcm had a smaller file etc etc than even the 97.
    You can swap just a trans w/o doing the whole wiring harness though. There's a how to on it.
  12. #12 Re: 4T-60 to 4T-65e HD swap
    Apr 2011
    Athens, Alabama
    Could you point me in the direction of that write up please?
  13. #13 Re: 4T-60 to 4T-65e HD swap
    Feb 2010
    my house
    the traction and ABS work as they did before
    98+ harness will not work becuase of the BCM not 100% sure why as i was not the one that did the swap or research
    adding in the 5 extra wires works too
    but the did find out why the OD does not work both transmissions had a bad 4th gear hub. the PCM is commanding 4th and is energizing the 1-2,3-4 solinoid
  1. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. L67 to L32 swap
    By kevins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2010, 07:07 AM
  4. L67 top swap
    By dbrincefield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2010, 03:26 PM
  5. L67 Top Swap on 05 L26
    By Luda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-09-2009, 10:53 AM
