Thread: Prop Rod
Results 1 to 10 of 10
  1. #1 Prop Rod
    Jan 2012
    At home
    Ok - this is embarrassing to write but, my 97 GTP has a "prop rod" ... does anybody know the part # to the retainer clip???
  2. #2 Re: Prop Rod
    Omaha, NE
    A dealer should be able to get you a part number. It might be easier and cheaper to pull one from a junkyard.
  3. #3 Re: Prop Rod
    Waukesha, WI
    yea if you pull it at a yard it would be afreebie
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  4. #4 Re: Prop Rod
    swap out the struts from a 98+ and never have to worry about it again
  5. #5 Re: Prop Rod
    Jan 2012
    At home
    Do you know the part #'s off hand?
  6. #6 Re: Prop Rod
    No i don't but you could probably pull the parts from a junk yard really cheap.
  7. #7 Re: Prop Rod
    SE Level Member Mater's Avatar
    Feb 2010
    my house
    ^^^ this
    and some 97s did come with gas struts. GM just ran out of parts same with why some have the mast antenna. the 97 GT has gas struts and the rear window antenna
    But why make it an SE?
    99 Grand Prix SE coupe:
    junk yard trans junk yard engine and junk yard turbo
    03 Silverado 2500HD ECSB: 6.0 4x4 01 Aurora:​ 4.0L vin number 2
  8. #8 Re: Prop Rod
    Jan 2012
    At home
    Not only was one of the lucky ones to get a prop rod, I also got a regular antenna (not a window one). How about that?!?!!? HA
    Junk yard is probably out of the question. I don't know if there is even one any where near me..
  9. #9 Re: Prop Rod
    Feb 2010
    my house
    try this site. it is a yard look up just put in the part and it will show the closest one and for how much
    car-part.com
    The Boss Iceman6669's Avatar
    Jun 2011
    Wow I musta got lucky, my 97 has the gas-lifts and the rear window antenna.
    2011 F-150 Yote powered
  1. hood strut arm prop
    By dpzelenak in forum Off Topic Discussion
    Last Post: 05-12-2011, 10:49 PM
