Thread: 2004 GTP misfiring & shifting hard from 1st to 2nd
Results 1 to 3 of 3
  1. #1 2004 GTP misfiring & shifting hard from 1st to 2nd
    Nov 2011
    illinois
    I bought the car a month ago from a private owner, it seemed to run fine when I test drove it. With in the first day the check engine light came on and it was idling rough. Had the plugs, wires (used a/c delco) and fuel filter changed. Changed the front and back o2 sensor. Also, cleaned the throttle body. It still ran rough took it to the dealership, it was a bad catalytic converter, had a new one put on also had fuel system cleaned. It is still running rough! The other concern is it randomly shifts hard from 1st to 2nd, usually when its cold but occasionally even after it is warmed up.
  2. #2 Re: 2004 GTP misfiring & shifting hard from 1st to 2nd
    Moved thread.
    Please post in the correct section for your topic.
  3. #3 Re: 2004 GTP misfiring & shifting hard from 1st to 2nd
    Portland Oregon
    I would take it back to the dealer and tell them they diagnosed the problem incorrectly because it's still running rough. As for the trans, it's probably a bad pressure control solenoid. When they go the PCM commands maximum line pressure so shifts will be hard.
  1. Shifting Problems Misfiring Maybe
    By Numbah in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-25-2011, 07:47 AM
  2. Shifting hard
    By zildjian102 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2011, 08:25 PM
  3. shifting hard
    By jaredbos 1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2011, 12:25 AM
  4. Maybe shifting too hard?
    By Claude in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-27-2010, 08:31 PM
  5. Hard shifting
    By Seagya in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2009, 09:50 AM
