Thread: Post your mod list
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Post your mod list
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    05 Impala Ls
    flipped dogbones
    cold air intake(filter under drvier headlight in front bumper) for summer
    warm air intake for winter(gas mileage)
    u-bend&resonator delete
    2.5'' catback exhaust(from 08 impala SS)
    headers or hv3 will be next, not sure which one to get first..
  2. #22 Re: Post your mod list
    Hmmm...
    '98 Silvermist GT
    Open Cone Intake
    L26 Aluminum UIM
    PEM's
    Cat & U-Bend Delete
    ZZP HV3
    Ported/Polished LIM
    AL606's gapped @ .050"
    Anchor Solid Engine/Trans Mounts
    ZZP Poly Squares/Bushings
    Lots of deleted brackets and other crap
    180* with the dexcool delete mod
    DHP Powertuned PCM running 33* Timing WOT
    Fer teh blue retarded mess....
    Engine:
    Bulldog Racing Engines Balanced and Align Bored L67 3800 Series II V6
    ARP Head Studs
    ARP Main Studs
    Clevite77 Main/Cam/Rod Bearings
    Balance Shaft Deleted
    GM '04+ L32 Powdered Connecting Rods
    GM '04+ L32 TTY Rod Bolts
    GM '03 8.5:1 Compression L67 Pistons
    Thrasher Engineered Performance Race Camshaft (.574/.566 114 LSA)
    GM LS7 Lifters
    Comp Cams Rocker Arm Bolts
    Intense-Racing O/R Stock Length Pushrods
    Bulldog Racing Engines Custom Ported/Polished L67 Heads
    Manley #130 Valve Springs
    Manley Titanium Retainers
    GM OEM Valve Guides Milled .100" for cam clearance
    GM '04+ L32 Valves
    Comp Cams Valve Locks
    Viton Valve Seals
    Ported Lower Intake Manifold Inlet/Runners
    Ported Factory GM GenIII M90 Supercharger:
    -Rebuilt using OEM GM Seals/Fluids/Bearings
    -Ported Inlet/Outlet
    -Machined Supercharger snout for use of pulleys smaller than 2.90"
    Custom LS1 Throttle Body Setup/Polished Adapter Plate
    SLP 85mm MAF w/ 9" Open Cone Intake Setup
    ZZPerformance Modular Pulley System: 3.2"/3.0"/2.8"
    160* Thermostat
    Custom HP Tuners Tuned PCM
    Stainless Steel Catless Headers
    3" Custom Catback w/ 4" G8 GXP Tips, 26" glasspack as a resonator and a 9" Bullet Proflo muffler before the "Y"
    MSD Ignition Coil Packs
    MSD Ignition 8.5mm Spark Plug Wires
    Autolite 103 Copper Core Spark Plugs
    Transmission:
    Triple Edge Performance Built 4T65E-HD
    3.29 Gears
    Trans-Go Shift Kit
    Full Rebuild with Hardened Clutches/Bands
    Hardened 4th Shaft
    7/8" Single Chain Setup
    Allison TransSend Transmission Fluid
    Suspension:
    Springtech Lowering Springs (1.8"-2" Drop All Around)
    ZZPerformance Anti-Pogo Washers
    GMPP Front Sway Bar
    GMPP Rear Sway Bar
    GMPP Rear Trailing Arms
    GM OEM 12" Brake Upgrade
    Drilled and Slotted Front/Rear Rotors
    ZZPerformance Poly Engine Mount
    ZZPerformance Poly Transmission Mount
    ZZPerformance Poly Round/Square Upper Mounts
  3. #23 Re: Post your mod list
    May 2011
    wisconsin
    Hmmm...
    '98 Silvermist GT
    Open Cone Intake
    L26 Aluminum UIM
    PEM's
    Cat & U-Bend Delete
    ZZP HV3
    Ported/Polished LIM
    Engine:
    ARP Head Studs
    ARP Main Studs
    GM LS7 Lifters
    GM '04+ L32 Valves
    Viton Valve Seals
    160* Thermostat
    Transmission:
    3.29 Gears
    Trans-Go Shift Kit
    Hardened 4th Shaft
    Suspension:
    GMPP Front Sway Bar
    GMPP Rear Sway Bar
    Wow!
  4. #24 Re: Post your mod list
    May 2008
    Winnipeg, MB
    engine mods:
    07 N/A 3800
    wizair cai
    hv3
    flipped dog bones
    synthetic oil
    coming soon:
    er rockers
    2007 Pontiac Grand Prix
  5. #25 Re: Post your mod list
    May 2011
    wisconsin
    Quote Originally Posted by tod1d View Post
    engine mods:
    07 N/A 3800
    wizair cai
    hv3
    flipped dog bones
    synthetic oil
    coming soon:
    er rockers
    On your 07 does your maf sensor bolt onto your air box or does it have a hose clamp? If it bolts on where did you get your cai?? I want one but all the ones I found have the wrong connection.
  6. #26 Re: Post your mod list
    May 2008
    Winnipeg, MB
    the maf sensor is in this kind of annoying tube that the air filter attaches to then a air hose goes to the throttle body
    old setup but it shows what I am talking about
  7. #27 Re: Post your mod list
    May 2011
    wisconsin
    I don't get why mine is different...... You have a house clamp on both end of your maf mines a house clamp on one side and a bolt on the other side... Two bolts connect my maf to the air box.
  8. #28 Re: Post your mod list
    GTX Level Member real diehl's Avatar
    Salina, KS
    hears my modz:
    2000 se
    ram aire intake with HUGE filter
    strate pipe exhuast
    ebay chip
    msd coils and wire
    platinum 4prong pluigs
    prob pushing about 300 whp, na
    signature removed for inappropriate content.
    -bio
  9. #29 Re: Post your mod list
    Out West
    300whp at -25,000ft DA.
    Whine with your Cheese?
  10. #30 Re: Post your mod list
    May 2011
    wisconsin
    Quote Originally Posted by realdiehl View Post
    hears my modz:
    2000 se
    strate pipe exhuast
    ebay chip
    msd coils and wire
    2000 se pushing 300whp? If its just the 3.8 then I'm guessing your at about 190-200 whp
  11. #31 Re: Post your mod list
    GTX Level Member crbquist's Avatar
    Massachusetts
    Mods in sig. Enough said
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
