Re: gas mileage
I drive this car to work 5 days a week, three miles away.
With no traffic, I can get home from work in 12 minutes.
However, I'm often forced to sit behind one lane backup every morning besides Saturday.
Side streets get me to work quickly after i can cross the train tracks and ditch the one lane road, taking around 18 minutes.
I'm seeing 200-220 miles from ~15 gallons of winter blend 93...
thus ~13-15 city mpg.
I need a daily driver for all this idling.
Re: gas mileage
the GTP is getting 24mpg average int he summer it was around 26-27 average
the merc gets 15mpg and about a set of tires every 3 months lol
900 mile road trip last week, averaging 70-80mph.....between 26-27mpg
01 GT 55,000 miles
Sent from my DROID RAZR using Tapatalk
Re: gas mileage
computer says i average 13.5 miles city, and about 18 highway. I dont doubt it either, I have quite a lead foot. I feel like it should be better though?!
Re: gas mileage
lol that's right where it should be I would say.
You can't expect to be a lead foot and get better gas mileage, if you hope to improve your mileage, your rpm's have to be under 3k.
I drive somewhat normally and still manage to pull off 16-18 mpg in the city.
Re: gas mileage
the reson my milage is i live out int he middle of the country and the closes city is 15 minutes or 30 minutes depending on witch oen i need to go to
Re: gas mileage
since the tune and downpipe i been checking my intown driving cause thats all this car gets, and getting 19-20 mpg intown with normal/reasonable driving, sure it will get better in the spring but still happy with the results.
Re: gas mileage
I was getting 18.8 with medium foot 21.3 with light foot in summer and fall and pulling around 30 freeway but now with the cold and winter gas I'm stuck around 15.3-16.7 city and 24 @70-75
Re: gas mileage
Computer says i'm getting 17.3mpg city and thats with 2 drivers and driving styles.
Re: gas mileage
I've probably wrote this before but this seems to be helping me alot. I drive 30min to an from work. 90% hwy. I was getting some pretty crappy mileage. I've recently tried not to beat on it like a whore and kept my rpm's no higher than 2200rpm at cruise. If you encounter a slight grade so what keep your foot there. You will slow down some sure... but you'll speed back up when you get to a downhill grade or level grade. This has taken my crappy mileage of 20-21mpg combined to almost 27mpg. Alot has to do with your tune as well granted but 80% of it is your right foot and the distance you are driving.
Also try to keep your tires properly inflated.
Just a little tid bit I thought I would share again.
Re: gas mileage
pulled 33 mpg going 50 mph cruise on a very straight road for 40 minutes, my old man was amazed as much as i was lols
Re: gas mileage
Im getting like 200 miles per tank :( 2004 gtp
Re: gas mileage
i re-did mine, i'm getting about 19-20 but thats a mix of thruway and city driving
Re: gas mileage
About 25-26 around town beating on ricers, playing road warrior. I once saw 28.1. From Orlando, to Miami, to Vero Beach I got 27.6 running 80-90 except inside Vero And Miami city limits.
Re: gas mileage
i get 17.2 when im driving normal and i drive like 20 miles a day usually and my gas gauge or range dont even work i ran out of gas a couple time before too
Re: gas mileage
Not sure how much on a full tank yet but just filled up and with using an eighth tank of gas I've pulled 70.3 miles. With 50/50 city/highway. Rather surprised with the factory fuel filter, kinda a dirty air filter, and a need of new plugs and wires. Wondering what brands you guys have found best use in filters and plugs, I was thinking ac delco for the plugs, wires, and fuel filter then either wix for a temp air filter or K&N for a more permanent replacement, any input? Thanks
Delco for plugs, wires, fuel and trans filter.
Note delco trans is an SPX Filtran filter. Unsure of origin of other delco products minus or filter. Those are champion labs econo design and should be avoided if you fear fram filters.
I'm enjoying my amsoil air filter more than either of my k&n's.
Re: gas mileage
Okay, thanks, on the car i owned before my gp, a 2000 jetta tdi, i had a K&N cold air intake i customized to fit the MAF into and on the forums for that everyone said that K&N is the MAF killer. I was just wondering if the sentiment here is similiar.
Eh... Only if you over oil.
However they don't seem to be the best at filtration which is key to engine life.
Re: gas mileage
anybody notice a change after putting in a cai? i havent put one in, just curious
