Thread: Modded 02 GTP Any way to estimate horsepower/torque?
Results 1 to 12 of 12
  1. #1 Modded 02 GTP Any way to estimate horsepower/torque?
    Mar 2014
    PA
    Hello, long time lurker here finally decided to signup, glad to be here in what seems to be a pretty friendly community here. Being a long time Pontiac fan and driver I bought a good condition 2002 GTP Fully loaded. I had since done several modifications however, no easy access to a dyno make me wonder what kind of power I'm putting out with my current mods. I understand that there are many many variables involved which makes it difficult to estimate power without actually dynoing the car but I was hoping some of you guys might be able to give me a rough estimate of how much horsepower and torque I might be making at the crank.
    Wizaired Cold Air Intake
    ZZP 3 inch downpipe with High Flow Cat
    ZZP PCM tune
    3.4 Inch Pulley
    90,000 miles on car, well maintained, always had synthetic oil
    I'm certain I have some knock since I'm running the stock ac delco plugs and thermostat, but I have some more supporting mods on the way like a 180 thermostat and some autolite 104's. I'm curious how much power that might add as well.
  2. #2 Re: Modded 02 GTP Any way to estimate horsepower/torque?
    Cambridge, Ontario Canada
    Depending on the knock, probably 240HP to 270HP at the crank
    2005 E55 - stock
  3. #3 Re: Modded 02 GTP Any way to estimate horsepower/torque?
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Get a scanner for knock.
    Driving a modded car without scanning is like banging a hooker without protection and HOPING you don't catch something.
    Depending on the car, you may see knock... you may not. I was seeing upwards of 6* with a 3.5 pulley. I had to get rockers to put an end to that. Some can run a 3.4* on just a downpipe with no problems.
    As to HP, I would guess around 270-275 at the crank... if you have no knock. So 220, maybe 230 at the wheels. Each degree of KR takes away about 5 HP.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  4. #4 Re: Modded 02 GTP Any way to estimate horsepower/torque?
    Mar 2014
    PA
    Thanks for the reply's guys. That is what I was thinking, around 270 to 275. Getting it scanned for knock is definitely on my to do list. Will the new plugs and thermostat help to reduce some knock? Without knowing what level of knock I have now, is there anyway of knowing what I would be putting to the crank after the new 104's and thermostat?
  5. #5 Re: Modded 02 GTP Any way to estimate horsepower/torque?
    SWPA
    Where are you at in PA? I'm in southwest PA and there are dynos all over the state. Hell there are two, an AWD and a 2WD dynos within 20 miles of me.
  6. #6 Re: Modded 02 GTP Any way to estimate horsepower/torque?
    Mar 2014
    PA
    To be honest I didn't really make a real hard effort to locate one. I just recently started modding the car, and don't want to pay for a dyno when I have plans of adding more bolt on's and supporting mods over the next several weeks. Once I get to a level where I have the few bits I want done, I will find one and have it run. I figured it would make due to come here and get some estimates.
  7. #7 Re: Modded 02 GTP Any way to estimate horsepower/torque?
    I'd say you're around 220ish hp
  8. #8 Re: Modded 02 GTP Any way to estimate horsepower/torque?
    Well if we already make what GM said was 240 hp and 280tq at the crank, with those mods just add 20.
    Wheel horse power will be around 220-230 after drivetrain loss.
  9. #9 Re: Modded 02 GTP Any way to estimate horsepower/torque?
    Mar 2014
    PA
    It's the torque I'm wondering about. With said mods does the torque increase typically match the HP increase?
  10. #10 Re: Modded 02 GTP Any way to estimate horsepower/torque?
    Feb 2009
    flintnasty MI
    The pcm has a torque pid you can scan that would be accurate for your car.
  11. #11 Re: Modded 02 GTP Any way to estimate horsepower/torque?
    You're probably at about 260-280 ft lbs of torque.
  12. #12 Re: Modded 02 GTP Any way to estimate horsepower/torque?
    Florida
    usually you gain a bit more torque then. on a 3.4 pulley typically it's 20hp gain and 30lb ft torque.
  1. HP Estimate
    By nik12937 in forum General Tech Discussion
    Last Post: 02-25-2014, 05:51 PM
  2. Horsepower estimate
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2012, 05:43 PM
  3. Estimate HP & WHP?
    By 99PontiacGTP in forum General Tech Discussion
    Last Post: 10-07-2011, 05:36 AM
  4. How to Tune the MPG estimate in the DIC.
    By lightfoot__ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 11:51 AM
  5. Can You Estimate My 1/4 now?
    By BLACKEDOUTGTP in forum Off Topic Discussion
    Last Post: 01-05-2008, 12:28 PM
