Thread: Heating Issue with My 2004 Grand Prix
Results 1 to 3 of 3
  1. #1 Heating Issue with My 2004 Grand Prix
    Aug 2024
    US
    Hi everyone,
    I am having trouble with the heating in my 2004 Pontiac Grand Prix, and I am not sure what?s causing it. The heater either isn?t blowing hot air at all or only gets warm for a few minutes before going cold again.
    This started happening recently, and I have already checked the coolant level and it seems fine. The engine temperature gauge looks normal too, so it doesn?t seem to be overheating.
    Has anyone dealt with this before? Could it be the thermostat, heater core, or something else? I would appreciate any advice or suggestions on what to check next.
    Thanks!
  2. #2 Re: Heating Issue with My 2004 Grand Prix
    St. Louis
    If the temp gauge is working and reading correctly then your thermostat is likely fine.
    When you checked the coolant, did you check it at the radiator or the overflow bottle? Having some heat then going cold sounds like a low coolant/air trapped system to me.
    Core could be getting clogged up.
  3. #3 Re: Heating Issue with My 2004 Grand Prix
    Apr 2014
    commerce twp,mi
    sounds like possible air in the system but I would suggest flushing the heater core,too.
    when cold and first started, sometimes its possible to hear air gurgling in the heater core if there's air in the system.
    08 grand prix NA3800
  1. 2004 Pontiac Grand Prix GTP - Transmission Issue
    By compro in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-23-2014, 06:20 AM
  2. 2004 Grand Prix Transmission Issue
    By Xeper in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2013, 07:04 AM
  3. 00 grand prix heating issue
    By keysarahmac in forum General Tech Discussion
    Last Post: 12-27-2012, 11:25 AM
  4. 00 Grand prix heating issue
    By keysarahmac in forum General Grand Prix Discussion
    Last Post: 12-23-2012, 12:53 PM
  5. 2004 Pontiac Grand Prix GT1 Issue
    By rawr in forum General Tech Discussion
    Last Post: 11-28-2009, 02:15 AM
