Thread: Cranks but doesn?t start
Results 1 to 4 of 4
  1. #1 Cranks but doesn?t start
    Aug 2021
    Texas
    So I?ve been having an issue where my 2004 Grand Prix cranks but doesn?t start.
    The first time it turns ON fine after the engine is cool, but if I turn the engine OFF after it gets up to temp like pump gas for instance, after that the engine just cranks but doesn?t start and I don?t hear the fuel pump prime.
    But, after a couple of hours it starts normal like nothing ever happened.
    Fuel filter has been changed
    Fuel pump still works
    Injectors have been cleaned
    EGR valve is new
    Anyone with the same issue or any tips to resolve I greatly appreciated.
  2. #2 Re: Cranks but doesn?t start
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    No prime is a major clue. Next time it fails to start, open the underhood fuse box, on the wheelwell, on the pulley side of the motor, right behind the battery. then have someone crank it over while you either wiggle or tap on the square relays. One of them is for fuel pump. If it doesn"t fire up try swapping f.p. relay with another one in the same box. Theres 4 or 5 the same in there. Cheap to replace at your local auto parts store.....E
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  3. #3 Re: Cranks but doesn?t start
    Aug 2021
    Texas
    The relays are good and fuses are not blown. I forgot to post that on the first post.
  4. #4 Re: Cranks but doesn?t start
    Aug 2021
    Texas
    Fuel pressure sensor ?
  1. Cranks but won't start
    By Thompsju in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2013, 03:41 PM
  2. My Grand Prix cranks, but doesn't fire
    By Moriachik in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2011, 07:02 PM
  3. Cranks but doesn't start sometime. Help!
    By Fluid604 in forum General Tech Discussion
    Last Post: 09-29-2011, 09:59 PM
  4. Car Won't Start... Just Cranks.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 10:23 PM
  5. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
