Thread: Clicking noise
Results 1 to 4 of 4
  1. #1 Clicking noise
    Aug 2021
    Texas
    Since I've bought my 2004 Grand Prix I've always noticed a clicking noise coming from one of the wheels. I noticed it only sounds when I turn right. Note: Break or not I can hear it when I turn right. Could this be the wheel bearing or the axle making that noise? Never had an issue until I thought to see if I can fix it. Any help or tips is greatly appreciated.
  2. #2 Re: Clicking noise
    St. Louis
    Could be either (or both). If you jack the front end up off the ground so the tires are hanging, push/pull at the 12 and 6'oclock position on the tire and see if you have play. If so, then likely a wheel bearing.
    To me a clicking noise would say CV shaft. Usually a hub bearing is more of a rumble.
  3. #3 Re: Clicking noise
    Apr 2014
    commerce twp,mi
    when turning right... could be the starter. theres a spring that returns the starter gear back into the starter after starting. when the spring wears and/ or breaks, the starter gear slides out during right turns and lightly hits the flywheel. it can sound similar to a cv joint going out.
    08 grand prix NA3800
  4. #4 Re: Clicking noise
    Apr 2014
    commerce twp,mi
    when&nbsp; turning right...&nbsp; could be the starter. theres a spring that returns the starter gear back into the starter after starting. when the spring wears and/ or breaks, the starter gear slides out&nbsp; during right turns and lightly hits the flywheel. it can sound similar to a cv joint going out.<br><br>
  1. Clicking Noise
    By NegativeOne13 in forum Brakes/Suspension/Chassis
    Last Post: 06-25-2013, 09:35 AM
  2. Clicking Noise
    By Adidasdude1989 in forum Brakes/Suspension/Chassis
    Last Post: 04-14-2012, 02:18 PM
  3. Clicking noise with key on
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-09-2012, 01:57 PM
  4. clicking noise
    By haasarmy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-14-2011, 05:04 PM
  5. clicking noise
    By whitegtp in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 05:11 PM
