Thread: AC leak
Results 1 to 4 of 4
  1. #1 AC leak
    Aug 2021
    Texas
    So I noticed the cold air just stopped coming out from the fan. I know it's not missing any cause even if some was missing you can know the air is cool not warm. I looked under the hood and see green liquid behind the driver side headlight. Or at least a round that area. Could that be where the leak is? Any help or tips would be greatly useful.
  2. #2 Re: AC leak
    The fluid is the PAG oil from the AC system. You are right to think that that area is where you leak is coming from. Whatever part is leaking needs to be fixed.
    Could be a seal at a connection point or the condenser is cracked and leaking. Hard to say without looking at it in person.
    It'll need to get vacuumed down after whatever repair is needed to make sure there are no more leaks, then it can be re-filled.
  3. #3 Re: AC leak
    Aug 2021
    Texas
    Turn out it the main ac line that goes inside my car. Or where the two lines go inside. Anyone know if its difficult to remove??? The two hoses that go inside my car???
  4. #4 Re: AC leak
    Aug 2021
    Texas
    Is there a special tool to remove the ac hose that goes directly inside my car??? Or is it just unscrewing the bolts holding it in place...
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
