#1
strange electrical issue
'08 base model. not every time, but a few times over the last 2 months, while driving the power has cut out for a split second. headlights, dash lights, stereo, everything. it happens so quick i dont know if the engine dies. its like flipping a wall switch for a light off the back on pretty quick. tach and speedometer do its startup jump,the display in the dash goes through its start up thing, and seat belt dinger dings like on start up.
i havent done any digging more than cleaning the battery terminal so far and hopin i might get some things to look at.
#2
Re: strange electrical issue
02-24-2022
check the small grounds on the trans bell housing, same place the neg cable bolts to. the wires start to break off the eyelets, you hit a bump and the wires move and power drops and comes back.
![](http://i.imgur.com/In0Qnqi.jpg)
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#3
GXP Level Member
02-26-2022
its very likely the ignition switch.
if you have more than a couple keys and fob on your keychain, remove em, the less weight the less likely it is to happen
![](https://www.grandprixforums.com/image.php?u=443&type=sigpic&dateline=1383215443)
~James~ Psychotic Gearhead
#4
![Quote](https://www.grandprixforums.com/images/redfox/misc/quote_icon.png)
Scottydoggs
ya ever been laying in bed- just about to fall asleep and something hits ya?
happened to me last night. thinkin about the grounds ya mention wondering why they may be a problem.
then it hit me- just as i was about to fall asleep. i had trans work done a few months ago. the problem started after that.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#5
Good call Scottydoggs.
Op, let us know what you come up with.
#6
update:
finally had warm enough weather to get my baby on jack stands, do some other work, and check out grounds.
i put new pos and neg terminals on the battery as they had been used and abused plus checked the ground on the trans. removed the paint on the trans, cleaned up the ground terminals, put it back together, have driven about 500 miles, and havent had the issue return so far.
#7
Good job. Thanks for the update. ls is still working OK?
#8
mrbreezeet1
hadda little elec issue since but cleaning the bat terminals and greasin em up took care of it.
