Thread: 2005 Grand prix front air bags replacement. Whats involved?
Results 1 to 13 of 13
  1. #1 2005 Grand prix front air bags replacement. Whats involved?
    Aug 2012
    MI
    Chats
    Do you just replace the blown air bags and move on with your day or are there any special scan tools or SRS modules that need to be replaced/reset after the front air bags have been deployed and replaced?
    I did a search but didn't see a writeup on removing the dash from a 2004+ grand prix. I bought a 2005 Grand prix with blown front air bags from lightly tapping a tree and the car just needs a bumper and hood. The drivers airbag was no problem but I went to a junk yard and tried to get the passenger side air bag out and it looks like the whole dash has to come out to get the passenger side air bag out.
    Does anyone have any pics/tips/advise on removing the passenger side airbag from a 2004+ grand Prix?
    I started taking one apart at the junk yard (it was 14 degrees outside today in Michigan) The plastic under the windshield started cracking like a potato chip and it looks like you have to pull the windshield out to get to the bolts to remove the dash.
    I did manage to get a passenger side air bag out but wrecked the dash in the process so I will have to try and get another dash when its warmer outside. Getting this dash out without breaking the fragile plastic is not going to be fun in the cold.
    My thoughts now are to just plug in the new drivers and passenger airbag and leave it on the floor to test and see if I got a good air bags from the junk yard. hopefully the SRS lights will go out on the dash. Just looking for some thoughts/advise before I do this. Don't want the passenger air bag to deploy again for some reason if its not mounted in the dash while I test to see if its good.
    Thanks in advance for any thoughts or advise!
  2. #2 Re: 2005 Grand prix front air bags replacement. Whats involved?
    Chats
    243824
    did the seat belts also lock up. like they wont come out or go back in?
    most of the time you need a module reset. pretty sure yours is under the pass front seat, under the carpet. its the box lump in the carpet.
    you would need both air bags plugged in to make the airbag light turn off.
    ive also seen where the plug ends that plug into the airbag burn up. so check them out.
  3. #3 Re: 2005 Grand prix front air bags replacement. Whats involved?
    Aug 2012
    MI
    Chats
    The seat belts are working fine at least since I bought it.
    I have an xtool A30M and a thinkdiag OBD2 dongles that can talk to the SRS system just haven't hooked it up yet to check.
    I ripped off the bumper cover off and replaced everything that was bent today. Nothing frame wise or radiator support was damaged so thats great! Bumper bar was caved it but a new one fit right in its place. Old hood even closed once I replaced the hood latch and bracket. Everything just lined right up with no persuasion so I know nothing got bent.
    I think I can even do some plastic welding and save the bumper cover. It broke by the Pontiac symbol but should be fine after plastic weld with the steel staples. Hood has a little damage up front and bucked just 1/2 - 3/4 of an inch so I'll just replace that. $50 at a bone yard for a hood is easier than bondo and painting. These cars sure are plentiful in the junk yard around here.
    Windshield and air bags next on the list.
  4. #4 Re: 2005 Grand prix front air bags replacement. Whats involved?
    Nov 2019
    WI
    Chats
    Quote Originally Posted by jj5428 View Post
    It's not all that difficult. You can either send out the module to have it reset or stick a used one in that hasn't had the bags blown. I did one on a Saturday morning.
  5. #5 Re: 2005 Grand prix front air bags replacement. Whats involved?
    Aug 2012
    MI
    Chats
    Thanks for the info. I'll grab the air bag module under the front seat and the wire connectors that may be burned for the front bag from the junk yard tomorrow.
    Thanks guys
  6. #6 Re: 2005 Grand prix front air bags replacement. Whats involved?
    Aug 2012
    MI
    Chats
    Yup, installed the air bags and cleared the codes with my xtool. The following codes came right back:
    B0051-13 Deployment Commanded
    B0058-17 RF pretensioner deployment loop open
    B0065-17 LF pretensioner deployment loop open
    Heading to the boneyard now to get the module under the passenger seat.
  7. #7 Re: 2005 Grand prix front air bags replacement. Whats involved?
    Aug 2012
    MI
    Chats
    Well I pulled the module and the seatbelts out of my current car before heading to the junkjyard. The front seatbelts do not have any wires that plug into them. Wonder how this system actually works...
  8. #8 Re: 2005 Grand prix front air bags replacement. Whats involved?
    Chats
    243824
    if the strap will still come out and lock when you snap on the belt they are fine. if not they locked up inside.
    when looking for a used module. make sure its not been under water, cowls leak, heater cores ect, and they get wet. will have a load of white build up around it if it was wet.
  9. #9 Re: 2005 Grand prix front air bags replacement. Whats involved?
    Aug 2012
    MI
    Chats
    ok figured this out. The air bag light is now off. I replaced the both air bags, air bag module from under passenger seat and drivers and passenger pretensioners (Where the seat belt clips into on side of the seat. There are wires coming out of these)
    Weird thing I noticed is when I removed the actual seat belts from the car you could no longer extend them out. I thought they were locked up but they had no wires going to them. Same thing happened at the junkyard when I removed the actual seat belts. So I installed them back in the car and then they worked fine again. It is repeatable and I can not explain why this happens....
  10. #10 Re: 2005 Grand prix front air bags replacement. Whats involved?
    Nov 2019
    WI
    Chats
    The seat belts have a counterweight in them so if their not held perfectly vertical they will lock up. Thats what locks them up when you slow down fast. Nice job on the airbags!
  11. Likes Scottydoggs liked this post
  12. #11 Re: 2005 Grand prix front air bags replacement. Whats involved?
    Aug 2012
    MI
    Chats
    That makes perfect sense.
    Thanks for the help Scotty and GXP02!
    Not sure I'd buy another air bag deployed car again. It was a good learning lesson. Got the car for $800 so it was worth it. Still have to do the windshield.
  13. Likes Scottydoggs liked this post
  14. #12 Re: 2005 Grand prix front air bags replacement. Whats involved?
    Chats
    243824
    you'd be buying 80's and older cars then to avoid the air bags. as they get newer and newer they get more and more air bags. top of the windows out of the seats. its like the spray foam when sly crashed the future cop car in demolition man.
  15. #13 Re: 2005 Grand prix front air bags replacement. Whats involved?
    Aug 2012
    MI
    Chats
    I'm ok with having air bags in the car. Just not buying another one with a blown passenger side airbag. I hate taking dashes out that have brittle plastic and doing windshields.
  1. 2005 pontiac grand prix base model stereo replacement
    By willdawg16 in forum Audio, Security & Visual Electronics
    Last Post: 05-22-2017, 09:33 AM
  2. replacement drop in struts for 2005 grand prix gtp comp g
    By Linebacker in forum General Tech Discussion
    Last Post: 03-15-2015, 08:43 AM
  3. 2005 Poniac Grand Prix front wheel bearings
    By bryanrhoads77 in forum Brakes/Suspension/Chassis
    Last Post: 11-20-2014, 11:43 PM
  4. Front Main Oil Leak...How Much Involved?
    By bassamore in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2012, 12:03 AM
