Thread: rack and pinion bellows/inner tie rod cover
Results 1 to 2 of 2
  1. #1 rack and pinion bellows/inner tie rod cover
    Apr 2020
    edmonton alberta
    Chats
    so after checking ball joints and tie rod ends it needed a ball joint and a tie rod end decided to put in new a arms by the way this is my gxp so anyway once it was all apart i noticed it needed a rack and pinion bellows so back to Napa and picked-up a bellows well after hours of trying to install the new bellows i find out that the gxp rack and pinion is slightly larger im sure you know that with the 5.3 v-8 sitting in the engine bay there's no room for your hand any way it was a struggle but finally got it on just info for others car was taken for wheel alignment and is good as new only 107000 kilometers approx. 70000 miles
  2. Thanks LouF thanked for this post
    Likes mrbreezeet1 liked this post
  3. #2 Re: rack and pinion bellows/inner tie rod cover
    Jan 2021
    Ohio
    Chats
    I had trouble getting my bellows boot on.
    Ended up soaking the bellows in almost boiling water for about 10 minutes and stretching it over a bottle overnight it let it expand enough to go on relatively easily.
  1. rack and pinion bellows/inner tie rod cover
    By waynerutherford in forum How To Write-Ups/Tech Tips
    Last Post: 10-23-2020, 09:15 PM
  2. rack and pinion
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2011, 09:53 PM
  3. rack in pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 10-25-2011, 04:28 PM
  4. rack and pinion
    Last Post: 02-21-2011, 09:53 AM
  5. GTP rack and pinion
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2010, 12:33 AM
