Thread: extended crank times
Results 1 to 3 of 3
  1. #1 extended crank times
    Apr 2020
    edmonton alberta
    so the regal has extended crank time, I've replaced the vacuum line that goes from the fuel pressure regulator around to the back of the engine the plugs, ac Delco 41-101 iridium, wires ac Delco 7 mm and the fuel filter so suggestions on the next move? fuel pressure regulator has no smell of fuel or leakage.
  2. #2 Re: extended crank times
    St. Louis
    How long is "extended"? I know I always let my GP prime the system before I fire it up and never had an issue. Other than that might be time to throw a fuel pressure gauge on it and see if it's running low.
  3. #3 Re: extended crank times
    Apr 2020
    edmonton alberta
    the crank times vary I always listen for the fuel pump to stop
  1. No crank, just click. Replaced starter, still no crank.. help!!
    By Steve98GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2013, 08:48 PM
  2. No crank. Replaced starter, still no crank. Now what.
    By suctoes in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2013, 01:22 AM
  3. How many times can a crank bolt be re used?
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2012, 06:26 AM
  4. Extended Warranty
    By THEJACKFROST in forum Canada
    Last Post: 06-12-2010, 09:40 AM
  5. Extended Warranties??
    By Blown97 in forum Off Topic Discussion
    Last Post: 01-19-2009, 11:59 PM
