Thread: PS pump replacement now no PS
Results 1 to 7 of 7
  1. #1 PS pump replacement now no PS
    Apr 2014
    commerce twp,mi
    im having a love hate relationship with my '08 base model. i love it but its hatin me for some reason.
    had the infamous pump squak and leaking so put a new one in today. filled and bled and had PS but then- just like that-gone. well- not comepletely gone. its there somewhat when the rpms are up a bit.
    im hoping i just have to bleed it more, buuuuut.... could i have a rack issue,too?
    08 grand prix NA3800
  2. #2 Re: PS pump replacement now no PS
    St. Louis
    How did you bleed it? On my 00 I had it in the air on stands so I could turn it lock to lock w/o resistance. Did that cycle for about 15 min, checking the level in the pump each time and filling as necessary. Was a PITA to get all the air out and kept foaming the fluid until it all got out. I also shut the car off to check the fluid in between and refill as necessary.
  3. #3 Re: PS pump replacement now no PS
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by FordMan77 View Post
    maybe not enough. im gonna flush the system this morning and see what happens.
    t
  4. #4 Re: PS pump replacement now no PS
    hangover park IL
    pressure valve may be stuckoff its seat and causing no pressure to build. ive had it happen several times with new/reman. pice of grit/fingernail/etc from assembly.
    you can hold a high rpm while tapping the valve bore with a lang screwdriver and small hammer (its the cylindrical portion you thread the 5/8ths fitting into (3/8in HP hose fitting))
    if it doesnt free up youll have to pull the pump out, toss it in the vice and remove the large nut on that cylinder (the nut is the part the HP line threads into) and youll have to pull it and the valve and spring will be there too, clean and reassemble after verifying the valve slides in the bore freely (youll need a small magnet to help extract the valve if you dont use needle nose pliers
    ~James~ Psychotic Gearhead
  5. #5 Re: PS pump replacement now no PS
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by Turbocharged400sbc View Post
    i flushed the system this morning following this procedure
    How to Flush/Change Power Steering Fluid on the 3800/3.8L Engine
    i got good clean fluid coming out,took it for about 10 mile ride and absolutely no power steering. when i was doing the wheel to wheel turn on the stands i could tell there was no PS. no squakin,though!
    since this is a brand new pump, if its the pressure valve, i think ill take it back and try another one.
  6. #6 Re: PS pump replacement now no PS
    Apr 2014
    commerce twp,mi
    update:
    i decided to try tapping on the vavle body. i have PS at 3k rpm but nothing at idle.
    still a valve problem??
  7. #7 Re: PS pump replacement now no PS
    Apr 2014
    commerce twp,mi
    UPDATE!
    dinked around with this #$*&^ thing yesterday. then went and got another pump this morning.
    problem solved.
  1. Help with water pump replacement.
    By rastatodd in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-17-2013, 06:41 PM
  2. Replacement engine oil pump
    By Booba5185 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2013, 01:51 PM
  3. Best fuel pump replacement
    By JDrach in forum General Tech Discussion
    Last Post: 02-17-2013, 09:51 AM
  4. 04 GT2 Water pump replacement
    By apok in forum Engine
    Last Post: 07-24-2012, 06:27 AM
  5. fuel pump replacement
    By rcode in forum General Tech Discussion
    Last Post: 12-09-2011, 08:39 AM
