Thread: ac condenser removal
Results 1 to 6 of 6
  1. #1 ac condenser removal
    pa
    I need to replace an ac condenser in a 2004 grand prix. Is it possible to remove the ac condenser by just moving the radiator forward and sliding the old condenser up and out? Thank you.
  2. #2 Re: ac condenser removal
    Maybe, even with the fans removed it's a really tight squeeze.
  3. #3 Re: ac condenser removal
    GT Level Member mguzzo's Avatar
    Buffalo NY
    i've done it on a 98, if you disconnect the top radiator tube and remove the fans you can push the radiator enough to slide the condenser out. Be careful not to bust up the fins or your knuckles
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  4. #4 Re: ac condenser removal
    pa
    Thank everyone for their help. One more question, I see one ac line is held on by a nut, but is the other one a quick disconnect type of fitting? Thanks again
  5. #5 Re: ac condenser removal
    Aug 2021
    Texas
    Had one replaced yesterday in a 2003 GP 3800,
    I do not mess w stuff I know nothing about, so.............I will send to $$$$ ($700.00+)
  6. #6 Re: ac condenser removal
    Aug 2021
    Texas
    how many posts must I make before mod approval?
  1. AC condenser
    By wowitsfast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-06-2019, 06:07 PM
  2. New condenser, then what ?
    By cheatah faheatah in forum General Tech Discussion
    Last Post: 05-06-2018, 03:49 PM
  3. 2008 grand prix condenser removal
    By daviddawg in forum Introductions/Noob Questions
    Last Post: 08-12-2015, 04:08 PM
  4. 89 GP condenser location
    By jasonbsb in forum General Tech Discussion
    Last Post: 09-08-2011, 11:54 AM
  5. 05 GTP Condenser
    By dsteinmann in forum General Tech Discussion
    Last Post: 05-16-2011, 05:46 PM
