Thread: Gears won't shift
Results 1 to 6 of 6
  1. #1 Gears won't shift
    clinton twp, MI
    Hello,
    So i started my car today, it started normally. When shifting my gears, the knob moves but nothing happens. My car stays in park. It seems that the shifter is a little more loose than normal. So i can move it to reverse or drive, but it does nothing.
    Does anyone know what this is? It is a 2004 grand prix GT2 3800- bought it new back then in 2004. It has only 130K miles.
  2. #2 Re: Gears won't shift
    St. Louis
    Shift cable is disconnected. Might have to open up the center console and see if the linkage is still attached.
  3. #3 Re: Gears won't shift
    Oct 2014
    portland oregon
    Check at the trans 1st its easier. Mine was broke there before and had the same symptoms as yours.
    Be advised if your cable is broke you still have to take the console appart to swap it
    Sent from my SM-N920V using Tapatalk
  4. #4 Re: Gears won't shift
    clinton twp, MI
    Quote Originally Posted by wowitsfast View Post
    I took the console off. Are there any pictures of what the linkage looks like under the hood?
  5. #5 Re: Gears won't shift
    clinton twp, MI
    That seems to be the issue. Now im a novice. Is this something a professional should do? How long does it take to fix?
  6. #6 Re: Gears won't shift
    Oct 2014
    portland oregon
    It's a deffinate dyi. If I can do it you can..trust me lol.
    Linkage is under the brake booster driver side. A little hard to get to.
    There is a mid point that I believe you can take it apart so if it's broke at the trans side you don't have to pull it through the firewall.
    Like scottydog said you can zip tie it to the linkage to get you by.
    I got mine from the junk yard few bucks
    Hope this helps you
  1. WTB 3:69 gears
    By Grimsin in forum Wanted To Buy - Parts
    Last Post: 06-20-2015, 11:50 AM
  2. Tranny Issue help! 1st shift is slipping/sluggish.2nd and up real quick jerk shift
    By Prixness in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2014, 12:28 PM
  3. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  4. gears
    By 443pearl in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-31-2012, 10:00 AM
