Thread: ABS Sensor and Harness Question
Results 1 to 4 of 4
  1. #1 ABS Sensor and Harness Question
    Mar 2017
    New York
    I see there are two different ABS sensor #’s ....I also see in other places they are interchangeable. Does anyone have a definitive answer ? I have heard that the doorman replacements are Not as thick as the OEM so I was going to go geez. Thanks as always.
    There’s any other additional parts you would recommend please let me know. I have been chasing lights for over a year. My mechanic had me change the cluster, the steering sensor , and bunch of other things. Light still comes on. I think I also had an additional issue which I believe it was resolved but still getting ABS light and traction control. Code goes back to things mechanic feels confident are not the issue.
    Amazon.com
    Amazon.com
  2. #2 Re: ABS Sensor and Harness Question
    St. Louis
    I've been rocking Dorman replacement ones from a local parts store on my 00 GT for years now with no issues. As long as you make a good solid connection and heat shrink the wires at the splice it shouldn't matter. No sense in paying more than needed just for a GM part on this one.
  3. #3 Re: ABS Sensor and Harness Question
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Which sensors are throwing codes? The front sensors corrode into the harness in the engine bay. If it is the front ones with the codes trace up into the harness. I have had no issues with the Dorman brand harnesses. I have used them on several cars.
  4. #4 Re: ABS Sensor and Harness Question
    Nov 2019
    WI
    Mine were broken at the first clip on the control arm. I spliced at that location, eliminated that clip and moved the harness towards the rear of the car to give it more room to flex. 6 months ago and no problems since.
  1. Abs sensor harness
    By grazin in forum Brakes/Suspension/Chassis
    Last Post: 10-06-2015, 11:38 AM
  2. Possible ABS Harness or Bearing Sensor Issue?
    By Dabman in forum Brakes/Suspension/Chassis
    Last Post: 07-15-2013, 04:47 PM
  3. speed sensor harness
    By dlk in forum General Grand Prix Discussion
    Last Post: 04-30-2013, 09:24 AM
  4. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  5. ABS Wheel Sensor Harness, HELP
    By foursixer in forum General Tech Discussion
    Last Post: 04-14-2012, 10:38 PM
