Thread: It died!!!
Results 1 to 10 of 10
  1. #1 It died!!!
    Oct 2020
    Mc Lain, MS
    We just bought a 04 grand prix 3.8 3 series. The day after we bought it, it died. It had a random idle issue, would cut out when cruising down the highway. Then it just died while driving. Now it won't start. Did some research, we replaced the MAP sensor and put in 3 new coil packs and wires. We have a MAF sensor coming tomorrow. No codes are showing! This is our only mode of transportation. Help!
  2. #2 Re: It died!!!
    Jul 2020
    Abbotsford, BC
    Have you actually done diagnostics? Does it have fuel and spark? Is the security light on?
    Throwing parts at it gets expensive quickly, enough parts and you could have paid someone to diagnose it correctly if you don't have the means to do it yourself...
  3. #3 Re: It died!!!
    sounds like a bad crank sensor.
  4. #4 Re: It died!!!
    St. Louis
    Yep, I agree with Scotty as it sound like a bad crankshaft position sensor. If you noticed the tach dropping to 0 while it was still running then that would be where I would start.
    FYI, if it's not a genuine Delco MAF sensor then I'd skip it. These cars don't get along with aftermarket MAF's. If it is the MAF then either source one from a JY or get a Delco one from RockAuto.
  5. #5 Re: It died!!!
    GTP Level Member
    Oct 2014
    A bad ICM can also cause those symptoms. More expensive part though. Use an ACDelco one.
  6. #6 Re: It died!!!
    Start by checking for fuel and spark. Like Scott said it's likely a bad crank sensor. If you check for fuel and have it, you'll be missing spark. Also check that the connections to the pcm and icm are not loose.
  7. #7 Re: It died!!!
    Oct 2020
    Mc Lain, MS
    We don't have the equipment to do diagnostics. My fiance used to be a general mechanic 15 years ago. There was no issue with the engine or trans and from what it was doing and what happened we knew it had to be something electrical or a sensor. We wanted to try to most common, cheap parts first before getting it towed to a shop. If the MAF doesn't fix it today, it has to go to the shop. Thank you for your help.
  8. #8 Re: It died!!!
    Oct 2020
    Mc Lain, MS
    Fuel pump is working, it turning on and pumping fuel, we checked that yesterday. It cranks but start. Does the crank sensor have to be programmed to the car? We have a **** ton of tools and a code reader but no way to program sensors if needed. That's why we started with the most common, cheaper sensors to start replacing first.
  9. #9 Re: It died!!!
    Apr 2014
    commerce twp,mi
    didja find the problem?
    08 grand prix NA3800
  10. #10 Re: It died!!!
    Jan 2021
    NewBethlehem Pa
    could be the catalytic converter. i had a similar issue and thought my engine was blown. turned out to be a catalytic converter. did a cat delete and runs great now.
  1. my maf died
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2011, 12:39 AM
  2. My car died
    By GPGTkid01 in forum General Tech Discussion
    Last Post: 10-20-2009, 08:25 PM
  3. died
    By Cjs02GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2009, 08:46 PM
  4. So..... The gtp has died... =[
    Last Post: 08-08-2009, 02:55 PM
  5. died
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2009, 06:21 AM
