Thread: Fading on front bumper
Results 1 to 7 of 7
  1. #1 Fading on front bumper
    Mar 2018
    NY
    The factory original paint on the top part of my front bumper under the headlights has lost its luster. Seems like the only way to get it back is to put a couple coats of wax on it, but that only seems to be a temporary solution. After a couple days its dull again. I havetried using a couple different waxes such as Meguire's cleaner wax, gold class & NXT (all of which I already had). Of course being black its that much more noticeable. Is there a more permanent solution that will last longer besides repainting?
    Fading on front bumper-img_99456-jpg
    Fading on front bumper Attached Images
  2. #2 Re: Fading on front bumper
    St. Louis
    Nope. My front and rear dark blue bumper covers suffered from dead clearcoat too. Did the exact same thing to try and bring it back and finally gave up. I got lucky and scored a clean pair from the JY and just swapped them out. Beyond that, strip and repaint is the only option at this point.
  3. #3 Re: Fading on front bumper
    Mar 2018
    NY
    Damn that sucks. Just a part of getting old I guess
  4. #4 Re: Fading on front bumper
    Dec 2008
    Lawndale, CA
    The photo is a bit small but it sounds and looks like clear coat failure. The only true fix is a repaint.
  5. #5 Re: Fading on front bumper
    GT Level Member mguzzo's Avatar
    Buffalo NY
    I get matching paint and cleracoat from here --> Touch Up Paint and repair | AutomotiveTouchup
    Plug in your color code and they can send you a spray can with perfect match paint.
    Scuff with 600 grit, wash with dawn and rinse, dry, mask, wipe with tack cloth, and spray away!
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #6 Re: Fading on front bumper
    Mar 2018
    NY
    The Guz, had to shrink it down to upload. That pic is 2 days after I waxed it. Probably is clear coat failure with it being plastic & what not.
    mguzzo, not sure I'm ok to paint myself lol, but that is good find there. Wish they had the gray on the bumpers too
  7. #7 Re: Fading on front bumper
    Apr 2014
    commerce twp,mi
    wash with dawn dish soap before anything. you want all wax off beforehand
  1. Replies: 0
    Last Post: 07-10-2014, 02:28 PM
  2. SE Rear Bumper/GT front bumper cover...
    By Mad Monkey in forum Visual/Body Modifications
    Last Post: 05-01-2010, 07:14 PM
  3. front bumper ?
    By Will5600 in forum General Tech Discussion
    Last Post: 01-04-2010, 03:59 PM
