Thread: Various Issues with the 00 GP, might have finally figured it out?!
Results 1 to 9 of 9
  1. #1 Various Issues with the 00 GP, might have finally figured it out?!
    Donating Users GT2000's Avatar
    Oct 2017
    Central PA
    Chats
    12144
    I have made a few threads months back about my car and the odd things it did. A recap, unsteady idle, hesitation on pullout but only occasionally, hard shifts under moderate throttle 3-4.5k rpm, Hard/long starting. Anyway, I had mentioned that i found UIM bolt sitting on the intake, not threaded in at all. I tightened it down and also torqued the others (that i could manage to get to) to spec, and none were to spec, so idk whats is with that. Anyway, the issue's still persist, but now 3k rpm's plus i have a turbo like whistle noise that gets louder the higher i rev it. Car only has 48k on it, but it's sounding more and more like a UIM gasket to me. Anyone's opinion is greatly appreciated!
    Also, should mention I used a smoke machine (all be it a homemade one, that runs on mineral oil) to check for vacuum leaks, but didn't see any. Also looked for any lose or off hoses, didn't see any.
  2. #2 Re: Various Issues with the 00 GP, might have finally figured it out?!
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    Chats
    I would say give cleaning your MAF sensor a shot. As for the whistle noise that may be something else.
  3. #3 Re: Various Issues with the 00 GP, might have finally figured it out?!
    Oct 2017
    Central PA
    Chats
    12144
    Oh forgot to mention, that is something i tried
  4. #4 Re: Various Issues with the 00 GP, might have finally figured it out?!
    Oct 2014
    portland oregon
    Chats
    507
    Have you checked your filter and or your inlet tubing?
    Holes can happen causing a whistle. My friends 05 GTP had simular issue with the noise. Turned out to be a tear in his stock inlet tube. The flexible part
    Sent from my SM-N920V using Tapatalk
  5. #5 Re: Various Issues with the 00 GP, might have finally figured it out?!
    Mar 2018
    NY
    Chats
    I wouldn't think the dreaded leaking intake manifold yet at your low miles, but obviously the car has been sitting for considerable time. I am a little suspicious of why the one bolt was not threaded in & the rest not to spec. Somebody must have touched it at some point. Telltale sign of a UIM leak is coolant pooling in the valley between the manifold & heads. Also if you spray brake cleaner around the manifold it will make the engine rev up by itself.
    Usually a whistling noise indicates some kind of vacuum leak. If the pcv valve was replaced with an aftermarket (non-acdelco) the whistling could be coming from that or if one of the two O-rings is missing in there or the map sensor hold down could have a broken tab. There was a design update which GM sold when you ordered a new pcv valve with a stronger hold down. Could also be one of the accessories running off your drive belt on its way out.
    Couple other things to try is cleaning the idle control valve, check the vacuum hose of the fuel pressure regulator (pull it off, no fuel should be dripping out) and as mentioned above clean the MAF sensor and check the wiring going to it
  6. #6 Re: Various Issues with the 00 GP, might have finally figured it out?!
    May 2020
    Pittsburgh
    Chats
    If you have access, watch fuel trims. Lean would indicate a vacuum leak as well.
  7. #7 Re: Various Issues with the 00 GP, might have finally figured it out?!
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Chats
    25
    whistle at idle would be a vacuum leak but it would go away as you rev (less vacuum)
    Try taking off your 710 cap, if the whistle goes away then check the PCV system
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  8. #8 Re: Various Issues with the 00 GP, might have finally figured it out?!
    Oct 2017
    Central PA
    Chats
    12144
    Took the oil cap off today after i got home today. Now that i think of it do notice a faint whistle at idle now that i think of it, but when driving only becomes very apparent after 3k rpm's. Took the oil cap off and seemed to have a zero effect on idle speed or sound. Inlet tube looks fine.
  9. #9 Re: Various Issues with the 00 GP, might have finally figured it out?!
    Oct 2017
    Central PA
    Chats
    12144
    New development today, engine light code P0102 Mass or Volume air flow A circuit low. Finally set a code, was worse then usual today when I would switch directions and be turning the wheel at the same time, the rpm would dip bad and power steering would weaken briefly and the car would make a weird noise. Idle was unsteady, even had a few weird shifts where it shifted at weird times I cleaned my MAF before, so I'm guessing that the I'm gonna need a MAF and hope that fixes all the weird problems I've been having.
  1. Figured id share this over here as well....
    By grandprixfamily in forum Visual/Body Modifications
    Last Post: 04-11-2013, 08:11 AM
  2. figured I would post this
    By shape275 in forum Off Topic Discussion
    Last Post: 12-11-2009, 04:34 PM
  3. New to the web site, just trying to get it Figured out.
    By McCalley08 in forum Introductions/Noob Questions
    Last Post: 01-27-2009, 02:52 AM
  4. I figured it out i think!
    Last Post: 10-17-2008, 11:35 AM
