Thread: would you replace fuel pump if doing the fuel level sensor?
Results 1 to 4 of 4
  1. #1 would you replace fuel pump if doing the fuel level sensor?
    canal winchester, ohio
    Chats
    replaced the fuel level sensor, cant get the darn snap ring on, wasted hours jerking with it. Come in here, see it takes two people or to just resuse the old gasket so.....I am now thinking of running up and wasting $90 on a new fuel pump with sensor and just reusing the original rubber gasket. Car has 180K. What a pain in the arse man!
  2. #2 Re: would you replace fuel pump if doing the fuel level sensor?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Chats
    25
    sand the snap ring and make sure its flat, clean and free of rust
    clean out the channels / notches where the snap ring sits in there
    coat the rubber ring with vaseline
    you should be able to push it down and get the ring in. Get one end of the ring in a notch and work it around with a small stubby screwdriver. it can be done by one person.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: would you replace fuel pump if doing the fuel level sensor?
    Apr 2014
    commerce twp,mi
    Chats
    you could consider it wasting money or time saved.
    could put that all back together and have the fuel pump go out in a week.
    08 grand prix NA3800
  4. #4 Re: would you replace fuel pump if doing the fuel level sensor?
    Chats
    I ended up putting the old gasket in, sanded the ring again and it went in like butter. Now that I know how to do it easily I can always replace the pump later. Thanks guys
  1. Brand of fuel level sensor
    By Hpiracr28 in forum General Grand Prix Discussion
    Last Post: 08-04-2016, 07:53 PM
  2. fuel level sensor not reading
    By chicagochuck in forum General Tech Discussion
    Last Post: 10-06-2015, 11:03 PM
  3. How do i replace the fuel level sensor in my GP?
    By mok4200 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-21-2014, 07:49 AM
  4. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
