Thread: metal in oil pan
Results 1 to 5 of 5
  1. #1 metal in oil pan
    Apr 2020
    edmonton alberta
    ok these are the bearings left is lifter middle is rocker right is what i found in the oil pan
  2. #2 Re: metal in oil pan
    Tough to see if it's reflection, does that resemble a roll pin or is it a solid piece? Do either of the ends appear to be cut/broken off?
  3. #3 Re: metal in oil pan
    St. Louis
    Does the engine still run perfect with good oil pressure and no strange tapping noises? If so then just run it till it dies and move on. I wouldn't loose any sleep over it.
    I found 2 random needle bearings in the last 3.8L I had the pan off of to repair the pan gasket leak. Not sure where they came from but the car was running fine before the gasket change. Still running strong today.
  4. #4 Re: metal in oil pan
    Apr 2020
    edmonton alberta
    car runs very good smooth bearing does not look broken off it is magnetic the others are not
  5. #5 Re: metal in oil pan
    I'm with Fordman, it's odd for sure and there aren't many things in the engine with that kind of bearing. If it's running strong and there's nothing showing you where it might have come from it's a goose chase.
  1. metal in oil pan
    By waynerutherford in forum General Grand Prix Discussion
    Last Post: 05-17-2020, 10:35 AM
  2. metal in oil pan
    Last Post: 05-12-2020, 04:08 PM
  3. Metal to metal grinding sound
    By luckyg817 in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2015, 04:48 PM
  4. Metal on metal grinding noise?
    By Pontiac Racer in forum Introductions/Noob Questions
    Last Post: 11-17-2014, 09:37 PM
  5. metal on metal sound
    By Toms04compg in forum Brakes/Suspension/Chassis
    Last Post: 03-21-2012, 04:54 PM
