Thread: Cruise Control
Results 1 to 2 of 2
  1. #1 Cruise Control
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    The cruise control is sporadically not engaging. No idiot lights, nothing on the DIC, just doesn't work, then after a key cycle or two, it does.
    Any ideas?
  2. #2 Re: Cruise Control
    St. Louis
    Simple checks- be sure both bulbs in the 3rd brakelight are working and the fuse is good/clean/tight. Might also want to check the brake switch to be sure it isn't sticking since IIRC the cruise will not engage if it thinks you are pressing the brake pedal.
  1. Airbag light on, no cruise control and no audio control
    By LutherLS in forum General Tech Discussion
    Last Post: 03-21-2017, 12:03 PM
  2. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2012, 10:19 PM
  3. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum General Tech Discussion
    Last Post: 07-30-2012, 07:16 AM
  4. ABS, traction control light and no cruise control?
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2012, 07:14 AM
  5. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
