Thread: Long Crank Start And Reduced Engine Power Problem
Results 1 to 2 of 2
  1. #1 Long Crank Start And Reduced Engine Power Problem
    Jun 2019
    Arizona
    Hello I have a 2004 Grand Prix 1 with 192.000 Miles.
    The Current Problems I have with it is,
    1st problem - It takes about 10 to 20 seconds of cranking the engine before it starts up, once it starts up it is fine to drive.
    2nd Problem - When driving, my car goes into limp mode "Reduced Engine Power" with a check engine light and i cant go above 1500RPMS, Some times it happens within 10 mins and sometimes it could happen a hour later sometimes i can go a week and be fine, it is unpredictable, I Usually pull over shut it off and restart my car, the Message goes away as well as the Check Engine Light.
    Parts i have Bought and replaced on the car with no luck yet
    - Fuel Filter
    - Fuel Pump
    - Spark Plugs
    - Spark Plug Wires
    - Coil Packs
    - Map Sensor
    - Maf Sensor
    - Throttle Body
    - Throttle Position Sensor
    - Air Filter
    - Oil Change
    I have replaced all these parts new but it has not fixed the problem, Anything that has not been listed that could be a idea to try next i would love to know to get my car running like it should would be awesome.
  2. #2 Re: Long Crank Start And Reduced Engine Power Problem
    HUDSON
    If you dont have a code reader/scanner, take your car somewhere that will do it for you (small fee or even free), to see what trouble they are before you start replacing any more parts.
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Reduced Engine Power
    By English05 in forum Engine
    Last Post: 09-04-2013, 12:04 AM
  3. 04 GTP Reduced Engine Power
    By orange57 in forum General Tech Discussion
    Last Post: 07-30-2013, 12:56 AM
  4. long crank no start but has spark
    By vamber58 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-05-2011, 07:10 PM
  5. Reduced Engine Power
    By donpedro_81 in forum General Tech Discussion
    Last Post: 09-22-2008, 07:20 AM
