Thread: 05 rear window broken
Results 1 to 10 of 10
  1. #1 05 rear window broken
    Jun 2018
    Lehigh Valley
    The rear window on my 05 will not go up or down. It will go up and down by manually lifting but will not go all the way up. When using the switch the motor makes a sound but it sounds strained. Can someone give me some guidance on how to get the window working again?
    '97 Grand Prix GT Coupe
    '05 Grand Prix GTP Sport Red Metalic SOLD
    '05 Grand Prix GTP Silver
  2. #2 Re: 05 rear window broken
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Pick up a new regulator, short money off e-bay. Springs, cables & cable guides .... something is pooched. Pop off the door panel & have a look/see.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  3. #3 Re: 05 rear window broken
    Pull the door panel off and remove the window regulator assemebly and motor.
    It's super common for the regulator to bind up and stop working. The motor is likely making that weird sound because it can't overcome the bind in the cables/regulator.
    I can almost bet you will just have to replace the regulator assembly.
  4. #4 Re: 05 rear window broken
    Jun 2018
    Lehigh Valley
    I have the panel off but I Don't really know what I'm looking at. Would a bad regulator prevent me from putting the window up manually?
  5. #5 Re: 05 rear window broken
    Jun 2018
    Lehigh Valley
    I took the cable off the bottom of the guide and am able to get the window up. I only see one bolt holding in the regulator and it will not come out. what's the trick? Also, how do I disconnect the cable at the window?
  6. #6 Re: 05 rear window broken
    Yes, it would.
    The cables and pulleys will stop the window from moving unless you unbolt the glass from the regulator itself.
    This is a general picture of what most regulators look like.
  7. #7 Re: 05 rear window broken
    cables cut it should go up and you can put a block of wood under it to keep it up till you get the new regulator. or the cable is still stuck on a slider.
    i just had to buy a back one for my regal, 36 bucks shipped from rockauto. ill be changing it next week when it shows up
  8. #8 Re: 05 rear window broken
    You could unbolt the glass bracket from the regulator and use tape the hold the window up.
    Do that or have two people when you replace it.
  9. #9 Re: 05 rear window broken
    ive got cardboard wedged between my window and inside door frame to keep mine up. it will only drop 2 inches tho.
  10. #10 Re: 05 rear window broken
    Jun 2018
    Lehigh Valley
    Thanks for the help! Happy 4th to you!
  1. 2004 Grand Prix GTP broken rear sway bar linkage
    By dbest1197 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2016, 11:46 PM
  2. Broken Rear Manifold Stud...
    By Thompsju in forum Introductions/Noob Questions
    Last Post: 10-14-2013, 06:13 AM
  3. HELP Rear seat tabs broken in 00' gp
    By Mellsthatguy in forum Visual/Body Modifications
    Last Post: 08-01-2013, 12:57 PM
  4. Window clip broken, please help!
    By VejGTP in forum 04+ Specifics
    Last Post: 11-01-2011, 03:25 PM
  5. broken window and mirror
    By Ryansgtp in forum Visual/Body Modifications
    Last Post: 11-08-2010, 05:14 PM
