Thread: Door Card Adhesive?
Results 1 to 2 of 2
  1. #1 Door Card Adhesive?
    Apr 2019
    Toronto
    Hey everyone, When i bought my GP (99 Gtp Coupe) about a month ago, I noticed the top left of the driver side door card would be loose from the actual door. But not in the way thats its missing screws, but were the door card meets the B pillar its out of place. I can push it back in but it ends up dislodging again after 10 seconds or a slight touch or bump. Is there an adhesive that holds the top left side of the door car to the door? or do is this a common problem for these GPs? Thanks!
    http://images.gtcarlot.com/pictures/49724595.jpg
    If you look at that image (Not my car) if you see on the top left, that corner of the door car is almost dislodged from the door.
  2. #2 Re: Door Card Adhesive?
    St. Louis
    IIRC, the upholstery is wrapped around the lip and stapled to the plastic backing. Then the black c-channel strip runs along the length. If yours is loose there then you could probably pull the door panel and put some gorilla glue under it and clamp it down and let the glue set.
  1. Replies: 0
    Last Post: 07-13-2017, 05:20 PM
  2. Adhesive Advise
    By BlackGT1 in forum General Tech Discussion
    Last Post: 05-21-2012, 11:54 AM
  3. adhesive for dash?
    By EricGTP in forum General Grand Prix Discussion
    Last Post: 03-14-2012, 01:18 AM
  4. window adhesive
    By Poil336 in forum General Tech Discussion
    Last Post: 04-10-2010, 02:50 PM
  5. Adhesive for GTP Badges???
    By adidasdude1061 in forum Visual/Body Modifications
    Last Post: 07-19-2008, 03:22 PM
