Thread: Transmission Shifter Issue
Results 1 to 7 of 7
  1. #1 Transmission Shifter Issue
    Jul 2012
    Bloomington, IL
    2007 GP Base 205K miles.
    Hoping someone can help with this. I don't think the transmission is the issue, but the gear shifter inside the car just slides back and forth like it's not attached to anything. Is it possible that there's a cable that snapped in there somewhere? Or the shifter mechanism is broken? My son dropped something off at a friends house, put it in park, and then when he got back to the car the shifter would just glide back and forth and he could not get it out of park.
    TIA
    Jeff
    2005 GTP - Headers, 3" DP, resonator, and catback, CAI, 605 plugs *Sold*
    2016 WRX Premium - Stage 2 E30
  2. #2 Re: Transmission Shifter Issue
    on the trans under the master cylinder is the cable end. its clip breaks. you can pop it back on and get it going again.
  3. #3 Re: Transmission Shifter Issue
    Jul 2012
    Bloomington, IL
    I slipped the thing back on to the top of the transmission, and now we're able to switch thru the gears. However, the plastic clip is broken, so I'm sure it will come off again. You wouldn't happen to know the part# for it, would you? I looked at Napa and it doesn't look like the same part.
  4. #4 Re: Transmission Shifter Issue
    this looks to be the fix. where to buy in the description under the vid/
  5. #5 Re: Transmission Shifter Issue
    Jul 2012
    Bloomington, IL
    Thanks. I go tht epart today, and will give it a shot tonight.
  6. #6 Re: Transmission Shifter Issue
    Jul 2012
    Bloomington, IL
    Just curious. Is there a way to remove the little arm so that you don't have to reach under there to install the new bushing. It's a pain in the ass.
  7. #7 Re: Transmission Shifter Issue
    you can unbolt the bracket that holds the cable, and there should be a clip that holds it in the bracket. not sure how that works tho. last time out i just took the bracket off. was doing a trans swap.
  1. Key & shifter issue
    By DIXIEJEANTHEQUEEN in forum General Grand Prix Discussion
    Last Post: 11-02-2015, 06:25 PM
  2. Transmission or Shifter problem....?
    By milwpacker in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 10-26-2015, 09:06 AM
  3. Gate Shifter Prototype from stock shifter (W.I.P.)
    By NinetyEightGTP in forum General Grand Prix Discussion
    Last Post: 07-17-2013, 04:28 AM
  4. 97 GP GT, shifter not moving transmission lever.
    By penright in forum General Tech Discussion
    Last Post: 06-24-2013, 01:27 PM
  5. Brake Shifter Issue?
    By doug331 in forum Brakes/Suspension/Chassis
    Last Post: 05-25-2009, 02:15 AM
