Thread: 05 grand prix gtp ...need help
Results 1 to 5 of 5
  1. #1 05 grand prix gtp ...need help
    Jun 2018
    WI (Wisconsin)
    Keep getting code p0340 has new cam sensor.rewired . checked all voltage everything is were its suposed to be..but still get the code car runs little rough at idle but has all its power and drives fine..has new gaskets from heads up new plugs wires icm and coils..what else can it be
  2. #2 Re: 05 grand prix gtp ...need help
    St. Louis
    Did you replace it with an OE cam sensor? Sometimes even new ones are bad out of the box.
  3. #3 Re: 05 grand prix gtp ...need help
    Did you check to make sure the magnet was still in the cam gear? Series 1 engines (never found in a W Body) were known to lose the magnet and usually it ended up in the oil pan. I am not aware that anyone has had the problem and the S2/S3 magnet was better. worth pulling the sensor out and checking that it's in place.
    The magnet can be seen here at about 8 o'clock in the cam gear.
  4. #4 Re: 05 grand prix gtp ...need help
    Jun 2018
    WI (Wisconsin)
    Yes replaced with a good sensor and i did scope the hole for sensor rotated motor and did see the magnet was there intact and tight......timing chain? Im receving signal to and from sensor so it and wires are good...starts up every time could the crank sensor be bad? Or out of time...but do have full power no miss a wot
  5. #5 Re: 05 grand prix gtp ...need help
    Time won't be off unless you took the timing set off and put it back together off a tooth or two.
    Having a reading at the cam and crank both should compensate for any stretch.. which isn't much at high miles.
    Might be a crank sensor..
    P0340 - GM Forum - Buick, Cadillac, Olds, GMC & Pontiac chat
  1. 2004 Grand Prix Comp GTP Rear Fenders/Quarters and Grand Prix Parts***
    By luckydogaroo in forum General Grand Prix Discussion
    Last Post: 01-30-2015, 04:00 PM
  2. Replies: 23
    Last Post: 06-21-2013, 12:52 PM
  3. Finding Grand Prix parts or Grand Prix's in Junkyards near you!
  4. 1991 grand prix 3.1 swap into 1996 grand prix 3.1
  5. Will a 04 grand prix 3800 engine fit into a 01 grand prix
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2010, 01:01 AM
