Does or can a catalytic converter rattle when it's going bad? It sounds like a loose heat shield and only happens under light acceleration up to 2k rpm's. I can't find anything loose under the car. The car isn't suffering from any of the usual performance issues when a cat goes bad and there aren't any check engine lights except for a recent P0455 large evap leak. The rattling has been happening for a while.
'97 Grand Prix GT Coupe
'05 Grand Prix GTP Sport Red Metalic SOLD
'05 Grand Prix GTP Silver
#2
Re: Catalytic rattling?
08-14-2018
it could, get under the car and bang on the cat to see if you hear it rattle.
![](http://i.imgur.com/In0Qnqi.jpg)
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#3
It does sound like there is a rattle coming from the cat when I bang on the exhaust. It won't be a problem if it rattles as long as it doesn't throw a code, right?
#4
08-14-2018
its gonna clog up on ya one day. so id plan to replace it.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#5
Is there a particular cat I should get?
#6
08-14-2018
Likely there's a shield on the cat.. they like to come loose. Take a look and if it's the shield, clamp it or weld it.
08-14-2018
theres no shield on the cat, its in the tunnel. it can come loose and rattle.
what brand depends on your year, 01 up you want a stock replacement, older you can get a hi flow with no issues. 01 up a hi flow cause over fueling and cat codes.
#8
08-14-2018
I'ts for my '05 GP. I took the tunnel shield off last year because it was about to fall off. I'll look again for a cat shield but I don't remember seeing one. Thanks for the info.
#10
08-15-2018
dont think the 04-5 have the cat test over fueling issue, i think you could get a cheap hi flow cat installed. or a zzp catted dp or a zzp off road dp and install a cat in it. if you change the dp, may as well get the 3 inch.
#11
GXP Level Member
08-15-2018
Some do, some don't. You're best off with a stock replacement.
#12
#13
rev it up and see what happens
YouTube
"Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
#14
Replaced the cat and all is good. No more rattle. What do I do with the old one? Trash or does it need to be recycled somehow?
#15
take the cat to a recycle scrap yard, you'll get about $40 for it.
#16
03-08-2020
my scrap yard offered just the weight. seems these cats are not wanted as much as the diamond shaped cats from the 80's.
#17
I'll put it in the pile of rotors and take it all at the same time.
#18
03-09-2020
now rotors add up, thats #1 steel. id be scrapping my own pile of rotors. thing is you need a pile to make it worth the trip.
id tell hey i got a cat...what they worth these days? seems its hit or miss these days from yard to yard.
